Deluxe Router Table...
Deluxe Router Table build
15 Users
Re: Deluxe Router Table build
seems like you enjoy those yellow tool eh... looking good as always. awaiting completion with some popcorn at hand...:D
Posted : 23/11/2010 2:47 am
chisel
(@chisel)
Toe kick finish.
Assembling base and partition. Now is the best time to attach the drawer runner before attaching the side. Use spacer here.
The Drawer Lock assemble for security.
Posted : 23/11/2010 3:40 pm
chisel
(@chisel)
Assembling the two sides of the car case.
Fitting the bit storage drawer.
Edge banding.
Posted : 23/11/2010 3:45 pm
chisel
(@chisel)
Drilling holes for the bit storage, used ½ straight bit since I don’t have ½” drill bit.
Cutting a recess for the drawer lock.
Posted : 23/11/2010 3:49 pm
chisel
(@chisel)
Marking slot for the lock to sit in.
Finish edge banding.
Posted : 23/11/2010 3:53 pm
chisel
(@chisel)
Installing the drawer front, used number 20 biscuit here.
Dry fitting the bit storage, hard ware use here seems like an over kill but this was a left over from a jewelry box project might as well use it before buying a cheaper one , will replace this if the right project comes.
Posted : 23/11/2010 3:54 pm
chisel
(@chisel)
Now for the wrench drawer , cut dado’s.
Drill hole for the khob.
And cutting drawer sides.
chisel
(@chisel)
Line up bit storage in preparation for finishing. Need to finish this first to put all my router bits.
Have a red paint laying around and waiting for it to expire so I might as well use it, I will paint it red.
Install leveling foot.
Posted : 23/11/2010 3:55 pm
chisel
(@chisel)
Now for the mobile base. If this succeeded I might incorporate it to all my shop furniture’s build. Start with a heavy duty hinge.
Posted : 23/11/2010 3:57 pm
chisel
(@chisel)
Attaching to the base of the car case, use a self centering bit to position the hinge.
The idea here is when I lift the car case the wheel should engage providing ease when moving and to disengage it I will need to install rope attach to the caster to pull it out and all the leveling feet should be in contact to the ground providing stability.
Posted : 23/11/2010 3:59 pm
chisel
(@chisel)
Use elastic rubber to act as a spring, staple it using stapling gun.
Attach the rope and find a heavy duty case handle with positive stop.
Posted : 23/11/2010 5:23 pm
chisel
(@chisel)
Now for the storage drawer. Batch cut all stock needed for the drawer.
Assembling the piece using glue and screw.
Provide a recess for the drawer lock.
Posted : 23/11/2010 5:24 pm
chisel
(@chisel)
Test fitting the storage drawer.
Partially finish router table put tung oil to protect from the elements. Next stop the top its been a long day bukas Vacation Leave uli ako. 😀
Posted : 23/11/2010 5:26 pm
Bro,
Anxiously awaiting for the build to finish and see it in action.
Where can I get one of this glue spreader?
Posted : 23/11/2010 7:35 pm
Bro,
Anxiously awaiting the finished build and see it in action.
By the way where can I get one of this glue spreader?
Posted : 23/11/2010 7:47 pm
Page 2 / 12
