Re: Deluxe Router Table build
Told you itβs a quickie one........!:D!
I like quickie too... π
ano yung router bit brand na gamit mo for cope and stick?
Canadian brand bro "blue tornado" acquire it last 2 years, 7 doors on its belt and so far no problem.
thanks for the info, I don't see much blue bits eh... nice set too...
very clean bro.available ba yan locally?if not,meron ba nyan sa EZ-cut?
EZ-cut has them, pero individual lang and not a set...
ok tnx bro,daming bits pa to collect.
buy them one at a time, walang katapusan yan brader... promise π
Finish sealing the MDF I have to seal it now before molds take over.
Now for the electricals use 2 circuit breaker one for the 110v transformer and the other one for the router.
Very near the finish because Iβm finish finishing. ... ..:)...
very nice work, btw, thanks for dropping by last monday and giving me a hand. had a good time having company... π
that is correct, when your finishing is finished, you know your finished... π
@ Chisel
Are you keeping the stabilizer there with the router?
@ Chisel
you meant step-down Jay? yes, as of last talk with Chisel, he fixed it inside with an axillary 110V socket hanging out of the front of his rt... his power switch is located on the side...
My pleasure bro basta may time ako daan ako dyan mis ko woodworking pag dito ako manila text text lang kita
btw Chisel, you still have to drill holes on the acrylic for the dc to work properly...
