Deluxe Router Table...
Deluxe Router Table build
15 Users
Re: Deluxe Router Table build
Jay this is the one I’m telling you about paint mixer. Especially if you are mixing hard epoxy primer
Is this the one from Ace? It's looks big and long or it's only the picture playing tricks.
Thanks for posting this. Soon I will be needing one. Will try to hook it up to an air drill.
Posted : 05/01/2011 5:07 pm
nice work brader, like the light to indicate that its plugged and powered. and yes it is truly a versatile design. congrats, that should serve you long and well... 😉
Posted : 05/01/2011 11:38 pm
ASTIG!!! you can make "quickie" projects with your RT na. congrats! seems like you are welcoming a prosperous 2011...more projects! more pics! more tools!:p:p mabuhay!!!
Posted : 06/01/2011 6:35 am
@chisel,
hanep! kabahan na mga kahoy sa iyo chisel bro!
wow saw some gorgeous big blue bits...what brand po nyan brader?haven't you auditioned them yet?
Posted : 06/01/2011 6:44 am
chisel
(@chisel)
Thanks Bro i owe it to you..
Posted : 06/01/2011 11:22 am
chisel
(@chisel)
@chisel,
Its a Blue Tornado brand Doc V i already made several doors using that bit its no longer on auditioned stage in fact i hired them for good he,he,he..
Posted : 06/01/2011 11:24 am
chisel
(@chisel)
In addition to the RT we need a jig to safely and accurately hold down the stock for this I build a coping sled. Here are the materials.
And a couple of motor cycle parts.:)
Posted : 15/02/2011 8:35 pm
chisel
(@chisel)
Cut a slot using the RT and this is also the part where I almost cry. Thought my Triton router broke as after this cut it won’t start. Have to remove carbon brush and clean it, relief as it start again.. hweew..
Drill counter sink using the DP.
Posted : 15/02/2011 8:36 pm
chisel
(@chisel)
Assembling the parts used anti slip tape so that the stock won’t move.
Test Routing.
Hold up very well.
Posted : 15/02/2011 8:38 pm
chisel
(@chisel)
Originally design by Infinity Cutting Tools, But you can also downloads plans through this web sites.
http://www.wwgoa.com/articles/projects/shop-made-coping-sled/
Posted : 15/02/2011 8:40 pm
I like it!!! 😀
Posted : 15/02/2011 8:45 pm
chisel
(@chisel)
Thanks bro..:D..
Always remember before routing this kind of materials to have a very good dust collector because it melts inn the router not in your hands....:)....
Posted : 15/02/2011 9:14 pm
Thanks bro..:D..
hehehe, so you did find residue of it inside :p... the router does have to breathe and it has to take in air and whatever is in it... glad things are fine. 😉
Posted : 15/02/2011 9:28 pm
Nice build bro. Very clean job.
Posted : 15/02/2011 9:38 pm
hey chisel,
no plans yet to make the groove for the miter slot? or nevermore?
i got a simple sled using a laminate flooring material and i wonder if i can somehow modify it by installing another toggle clamp that is adjustable at the front end.
but whoa, yours is a nice build that will serve you well from hereon.
cheers!
Posted : 15/02/2011 9:42 pm
Page 8 / 12
