my router table bui...
my router table build.
15 Users
Re: my router table build.
now i believe tuffply is made somewhere in the south..
and how much is one sheet 3/4" ding?
thanks much..Paco is the only one nearest to me.
anyway, i wont be be building boats in the near future so id settle in the meantime with my trusty Uniwood.
V
Posted : 03/12/2011 6:47 pm
V
I too get my Tuffply with Ms. Lisa Lim... 2k each yan brader two years ago...
Posted : 03/12/2011 11:08 pm
palagay ko tuffly brand yung sa meycauayan na yun...
anyway, thanks ding, great info on those tuffly plywood...
Posted : 04/12/2011 12:12 am
@ Violaine
May of last year, these were the prices of what I bought:
5mm = 500
9mm = 900
12mm = 1,200
Parang 100 pesos per mm. Not sure what the prices are now.
Just to give you an idea of the quality, the 5mm has 5 ply and the 12mm has 7ply. Masinsin. And both sides are usable.
Posted : 04/12/2011 5:50 am
P100/mm ... easy to remember ... those were the days
Last I checked,
3 mm - anyone know the story with this?
5/5 - P500 -> 560 -> 600
9/7 - P900 -> 960 -> 1,100
12/7 - P1,200 -> 1,450
15 mm - not manufactured?
18/11 - P1,800 -> 2,000
Posted : 04/12/2011 7:16 am
been very very busy...
manage only to put grooves for the drawer bottom.
i don't have a dado blade,
so my ts blade's kerf will be used to create the desired width of the cut
and a shim will allow for a single set-up for cutting the groove to fit the drawer bottom...
then do a sinlge pass...
remove the shim and make another pass...
test fit the grooves with the 1/4 plywood for the drawer bottom...
Posted : 04/12/2011 9:56 pm
manage to glue 4 drawer boxes...
i only have 6 pipe clamps and a pair of f clamps,
tpmorrow will be the remaining drawers...
Posted : 04/12/2011 10:51 pm
Go go go jhon tapusin n yan malapit n mapalabas aking science fiction ko hehehe nice built master jhon
Posted : 07/12/2011 4:16 pm
@jon,
tanggalin mo na mga clamps bro..tuyo na glue..
inip nako sa rt mo.
sarap siguro mag woodwork ngayon..malamig..hindi madaling pawisan..kaso mahangin lang..hassle pag nagka cut ng plywood using the cs outdoor....super dusty! well, those were my memories...matagal tagal na din ako hindi nakakasinghot ng kusot at alikabok ah..
forever lurker na lang ba ako?
Posted : 07/12/2011 6:15 pm
ryo,
ipakita mo na kasi yang sci-fi blockbuster mo, para may ibang mapanood dito,
at para hindi naman mapansin tong kabagalan ng build ko ...
V,
😀 😀 kinalawang na nga yung mga clamps V,
totoo, masarap gumawa ng projects ngayon, mapa-metal o mapa-wood,
malamig kasi panahon...
actually, ngayon lang tumigil ulan dito sa amin.
and can't take advantage of the cool climate
atat na atat na rin akong matapos tong rt build ko,
very busy lang talaga...
toxic sa work...:outcold:
gawa ka na kasi ng projects para ma-inspire naman kami dito...
Posted : 07/12/2011 10:30 pm
Ok lang yan Jon ... mas maganda build pag hindi minamadali .... 🙂
Posted : 07/12/2011 11:45 pm
thanks jayL,
sa sobrang bagal ata ng build ko, mukhang aamagin na ang plywood na ginagamit ko...
anyway here's an update of a typically slow rt build.
here are the finished drawers ...
some are not that square,
my plans are to make the drawer's front flush to the wood-edging.
hirap pala gumawa ng ganon, i should have made it overlapping the cabinet,
like the very first time i made a drawer.
anyway,it was a joy and lots of learning experience building these drawers.
to continue,
putting the wood edging...
used finishing nails and nailed it deep down with a nail set ( medium size )
later i'll be trimming those excess woodedging...
Posted : 11/12/2011 11:38 pm
attaching the false front to the drawer,
but first have to smoothen first the pieces with a handplane...
a dab of small amount of glue...
then screwed.
Posted : 11/12/2011 11:46 pm
fitted the drawer...
this what happens when the drawers are not square,
it shows when you fit the drawer.
got to find solutions later on...
and here's another one,
a fifth grader will be laughing,
once they saw that little space at the upper left corner...
kakaasar!!!
paulit ulit na nga akong nag-divide, gumamit pa ako ng calculator, may gap pang lumitaw...
i really hate math !!!:mad:
dumarami ang problemang dapat solusyunan !!! :surfing:
to be continued ulit,
all this activities done this weekend.
pasundot-sundot lang kasi,...
Posted : 11/12/2011 11:59 pm
wala naman ah? di ako naka salamin eh....
Posted : 12/12/2011 12:05 am
Page 4 / 8
