my router table bui...
my router table build.
15 Users
Re: my router table build.
v,
i just checked the drawer pull's location...
and you're correct,
most of them place the drawer pull at the center of the drawer ( checked timber's, chisel's rt )
i'll change it's location as soon as i have the time for my rt build...
thanks V...
Posted : 20/12/2011 12:29 am
Re your question about wires and Phelps Dodge: Yes, that brand is available locally. You can get the THHN type which would be thin (easy to put into a conduit) and has good heat resistance.
Some good discussion here: http://pinoyhandyman.com/showthread.php?t=248
Also, Phelps Dodge site is here: http://www.phelpsdodge.com.ph/Word%20Documents/THHN.pdf
I got mine from Ace but I think they're also easily available in hardware shops.
Posted : 20/12/2011 3:27 am
Gauge 12 is P30 per meter in a nearby hardware store, P3450 per box (150 meters).
Wilcon and others sell them at P33/meter, even if you buy the whole box.
Posted : 20/12/2011 7:21 am
thanks very much sir ding...
very big help tong wire thread na to.
what concerns me most is this locally available flat cord that i put,
it has a very thick rubber insulation,
but the wire strands are thin and easily loosens and cut out.
poor quality as it may seem.
reviewing my rt electrical connections;
i'll be plugging my 1850 watts (3612c ) router to a seperately but encased circuit breaker
rated at 20A ( koten brand ).
then connect it to the on/off switch,
through which i used this flat cord to connect to our home outlets.
gusto ko na tuloy palitan yung flat cord ko ng phelps dodge wire...:eathis:
(sorry for the dodge phelps )
Posted : 20/12/2011 7:57 am
thanks joey,
i'll check it out as soon as i have the time...:sunny:
Posted : 20/12/2011 8:24 am
Phelps Dodge is a good wire and cord brand. It's the one I use to wire my shop and power my welders.:thumbup:
Posted : 20/12/2011 4:57 pm
hindi ko kasi alam na may cord din ang phelps dodge...
maghahanap na talaga ako neto...:diver:
:thanks:
Posted : 20/12/2011 11:07 pm
jonathan nice RT ang ganda naman yan sawakas tapos na pala yang table mo heheheh congrats bro aba sampolan mo na yan ano pa ang next project mo? hehehehe
Posted : 26/12/2011 9:46 am
hindi pa tapos ito bro, marami pang kulang...
hindi ko pa masundan yung rt build,
been very busy...
Posted : 26/12/2011 10:29 pm
@jon,
i bought the same size locking casters as yours...and i am not really happy moving the rt around..i guess bigger wheels are much free wheeling than smaller ones but my router table is in series already in terms of height with the TS..so i guess i have to live with it..unless i snatch some free time to cut the rt legs!
you know what, there is this idea of mine and been cooking it all this time why not we publish a bi annual magazine about woodworking...(rosy and jay will handle the metalworking section or well..another magazine;))
it is no longer a thought...its now an obsession:eek:
so please document your wips using a lot of pictures...in this age of digital cameras, we dont worry about films anymore.
i hope by late early 2013, we can have the first edition.
jarod will be the editor in chief...timber will be the chief shop carpenter/tool test editor..moji the chief designer...
well its just a list...oops i forgot..Jay will be the publisher!
ahahhahahahahahaha!
si ryobi??? visiting shop consultant ba tawag dun? sa ospital kasi me ganun! o kaya master fabricator?...weeeeeeeeeeee!
si owyn? hmmmmm bagay sa kanya refurbishing section siguro.
si chisel? si deWalt master yan!
si bryant...laminate works..
well you could assign work for ernie...willy...bigfoot...i ran out of ideas now eh.
eh ikaw jon...bahala ka muna sa balot!
ako? hmm....lay out editor na lang po!
V
Posted : 27/12/2011 6:16 am
@jon,
V
go go go V, call ako dyan, maraming balot dito, pampagana sa mga obsession nating lahat...
malaki ang maitutulong ng iniisip mo V,
in all aspects of these hobby of ours,
mapa- metal, wood, concrete, cars...
everything that can be DIY'ed...
:massbounce:
Posted : 27/12/2011 10:34 am
Go go go ....
Posted : 27/12/2011 10:56 am
W O W !!!! Very very nice idea and concept V, well I guess every active member who does WIPs not necessarily given a position can just be a contributor of projects/wips to the bi-annual magazine.
GREAT IDEA !!!! GO GO GO GO !!!! :thumbup: :2thumbsup: :clap1: :clap:
Posted : 27/12/2011 11:30 am
continuing my rt build ...
can't find phelps dodge flat cord,
but i found a locally made flat cord ( philflex )
but of good quality ( i think ) than the first one i used...
this will be the electrical outlet of the router...
then i temporarily fixed ( screwed ) the top to the body.
Posted : 07/01/2012 7:38 pm
it's time to play around with the rt...
putting the rt plate ( incra ),
and wondering as i can insert or remove the bit above the table.
Posted : 07/01/2012 7:44 pm
Page 6 / 8
