My workbench build ...
My workbench build (Jonathancruz)
11 Users
Re: My workbench build (Jonathancruz)
[IMG] [/IM1/4 chamfer around the bottom of each legsG]
Posted : 02/11/2010 7:02 am
with the tenoning jig,create a tenon on each edge of the stretchers.
Posted : 02/11/2010 7:04 am
[IMG] http://i1212.photobucket.com/albums/cc448/jonathanscruz68/DSCN00762 .jpg[/IMG]
Posted : 02/11/2010 7:07 am
at legs, i make a hole in each mortises making it centered,to recieve the 4"x3/8 bolts to meet with the stretchers.this will hold the stretcher with the legs.
Posted : 02/11/2010 7:15 am
with the hole on the legs,make this as a guide and make a hole on each tenon of the stretchers.
Posted : 02/11/2010 7:18 am
hole on the sides of each stretcher for nuts access.
Posted : 02/11/2010 7:20 am
flat bottoming with chisel, for nuts easy entry.
Posted : 02/11/2010 7:22 am
gluing up the legs and lower rails,and screwed the top rails
Posted : 02/11/2010 7:52 am
attaching the stretchers with the legs.
Posted : 02/11/2010 7:54 am
Posted : 02/11/2010 7:55 am
with legs standing up and tied together with the rails to form two end frames.then with the stretchers, i connect the frames,to create the base.creating a solid base is a prime importance because this will bear all the tortrous chores in woodworking.
Posted : 02/11/2010 8:09 am
looking sturdy jonathan!
no plans of making the recess for the bolts?
Posted : 02/11/2010 11:10 am
should have made a recess,but i already drilled the holes for the nuts to the exact lenght of the bolt.mas maganda nga tingnan kung nakarecess.changing the bolt lenght will do so.siguro later na lang,sa excitement na mayari ang workbench,hindi na naisip lagyan ng recess hehehe.thanks very much doc.
Posted : 02/11/2010 11:28 am
I don't know if it's only me but I see "This image or video has been moved or deleted" icon messages. These aren't actually what it seem, It's just that the image codes are somewhat disarranged thus the images cannot be viewed.
FWIW, the links below are some of the missed images of the posts above. I wished to post them as images but they are too many so I just decided to post the links instead.
Posted : 02/11/2010 2:14 pm
@jarod,
thanks for making the time to post these "This image or video has been moved or deleted" wips.
@jonathan,
what type of glue did you use to sandwich the leg supports?
naku nag eenjoy kana masyado sa woodworking ha!
perhaps at the end of the day you feel tired but satisfied.
sino ba assistant mo? hehe
Posted : 02/11/2010 4:33 pm
Page 2 / 11
