Re: TS mobile base with RT
I like the idea but my workspace doesn't. That is also one of the main reason why I cannot purchase a TS as well 🙁
eto brader, pwede kung ayaw mo ng ts. Plunge/Tracksaw (hope you understand German, though video speaks for itself) , maglalabas na Bosch soon....
Kapag gusto, may paraan. Pag ayaw, maraming dahilan. 😀 😀 😀
Ok sana kung libre/mura brader, kaso mas mahal pa yan sa table saw :unsure: Btw, I know a little German - the presenter says "this is very expensive" 😛
Hindi ba "Pag walang pera, maming dahilan" 😀
brader, you might not need the plunge saw, but the track along with any compatible cs will work as well. so technically, it is soooo much cheaper than a ts...
eto catalog, convert mo na lang cost.... D&M you can also move to the next page to see the plunge saw kit... :thumbup:
@timber:
Tingin ko baka gumawa na lang ako ng DIY track saw. Pero mas trip ko gamitin yung Makita SH01, para ala ruler and cutter style lang. Problem lang is very minimal yung availability ng 3 3/8" circular saw blades.
@joey81:
Kelan kaya kami makakapanood ng sample videos in "TS-in-action" mo? 😎
@joey81:
Napaka-demanding naman nito. Video naman ngayon. 😀
Baka matagalan pa. Hindi ko mahawakan dahil sa ulan, eh.
Joey, in this picture the ts fence side is on the support side table
do you plan to extend the fence mount? kasi if your cut capacity is 25", without making modifications sa fence mount, it will still have a 25" cut capacity...
The fence's locking mechanism is fairly simple: iniipit lang yung table top. The initial plan was to make RT the same depth as the TS top. This way I can also make the fence lock on the router table.
Later I realized that the RT would be too small if I stuck with that plan. Now I'm going to make the RT bigger. And for the TS fence I'm thinking of making one based on the T-square principle. Quick setup time, provided of course that the front edge of the RT is straight and perpendicular to the TS blade.
goodluck on the build specially the fence mod, please make sure it would be very secure. This will not only cut your nails... keep safe.
Will be using the trusted F-clamps to hold it in place. Thanks!
Was able to spend time on the project today.
Still have some spare roofing material lying around:
Marking the outline and bend lines.
Poor man's sheet bender
Now where's my rubber mallet?
When you lose something you just have to trace back your steps and remember what you did before. Soon you will find what you lost:
Now back to the project:
Voila!
But something went wrong with my measurements.
That edge should be vertical! 😡
Disaster recovery:
