TS mobile base with...
TS mobile base with RT
13 Users
Re: TS mobile base with RT
View from down under:
From the top:
Posted : 02/10/2011 9:56 pm
These were taken last Sunday. Only had the chance to upload today.
Found an aluminum "tail pipe" at Federal Hardware:
Which is roughly of the same diameter as the Zekoki pipe:
Pilot holes
Free-hand routing with EZ-Cut shear-cut flush-trim bit
Posted : 04/10/2011 11:04 pm
Pwede na
Nice fit:
Fed-Seal to seal and secure the pipe:
Posted : 04/10/2011 11:06 pm
Innards of the Chin TS
Another piece of metal sheet:
After a few cuts and folds:
Posted : 04/10/2011 11:09 pm
This should help in minimizing the sawdust that blows out to the front
View from the other side:
Posted : 04/10/2011 11:13 pm
" Disaster Recovery " ... I love this DIY term .... :attack:
Posted : 04/10/2011 11:22 pm
But something went wrong with my measurements.
That edge should be vertical! 😡
Disaster recovery:
Posted : 04/10/2011 11:23 pm
ayos to brader Joey, malaking problema ko din ang dust....pakopya ha!!
Pero...what puzzled me is the color of the blade...magkaiba talaga ang kulay bawat side?
Posted : 05/10/2011 7:02 pm
Magkaiba rin ang size bawat side. 😀
The red one is a 40-tooth 7 1/4" Diablo from my CS. Yun kasi ang nakalagay when I installed the dust guard. Tapos naisip kong baka hindi kasya yung 10-inch. 😮
Posted : 05/10/2011 8:08 pm
parehas pala ng mechanism ng ryobi TS
ano na nangyari dito? hehehehe ano na itsura ng TS mo ?
Posted : 06/11/2011 4:35 pm
It's been a while. Too busy with other things in the house and most of the time too tired when I get home from work.
Somehow got to work on the RT top this weekend. Still not much progress, though.
My plywood cuts aren't true off the bat. So I use a pattern bit and a straight edge to route one edge true:
The use that edge as a reference to true up the other edges:
Posted : 20/11/2011 6:42 pm
The RT top will hold the table saw rip fence for wide cuts. So its alignment with the TS top is critical.
I'm sure it won't be aligned when I screw it into place, so I thought of a different way of attaching it to the base.
This is the base where the top will be attached:
This is the bottom half of the RT top:
With the 1/4" bolt in place:
And the wing nut at the bottom:
Posted : 20/11/2011 6:51 pm
A dab of epoxy will prevent the bolt from spinning inside when I tighten the wing nut:
Glue up time!
Whoever said you can never have too many clamps is a genius. I'll get maybe one and a half dozen clamps from Harbor Freight next time.
Posted : 20/11/2011 6:56 pm
Master, ito na ang itsura ngayon
Malayong-malayo sa whiiiirrrr-whiiiirrrrr mo. :worthy:
Posted : 20/11/2011 7:50 pm
@joey,
you might have used a flush trim bit rather than a pattern bit.otherwise, you could have messed that aluminum bar level.
why didnt you use cauls to improve your clamping?
you can borrow mine if you need more clamps.
:apple:
Posted : 21/11/2011 6:30 am
Page 3 / 6
