TS mobile base with...
TS mobile base with RT
13 Users
neilman
(@neilman)
Re: TS mobile base with RT
good job Sir Joey, LIKE (wala bang like button?)
Posted : 26/08/2014 11:08 pm
Galing Joey.. a mobile 2-in-1 workstation with lots of storage..guapong guapo ang Bosch TS. Ang sarap mag woodworking dyan.
Posted : 27/08/2014 11:07 am
Joel
 Joel
(@joel)
nice project sir joey..
Posted : 27/08/2014 2:29 pm
Thanks Armand, Joel, neilman!
Progress has been very slow. Shop time is only a few hours a week.
RIpped some 1/4" plywood for the balde storage
Now for the wooden "plugs" that will hold the blades
Plugs already cut, but still connected to the stock
Now to release the plugs
Posted : 14/09/2014 9:17 pm
Snug fit
BTW, I already installed a safety paddle switch
The switch controls an extension cord built into the station. Now I can easily turn the router ON or OFF.
Power to the GTS1031 also goes through this switch.
This is a 2-pole single throw switch. Since only 1 pole is needed to control the TS/router, the other pole can be used to simultaneously control othe equipment. A 220V vaccuum cleaner, perhaps?
I now have storage for 12 blades. Expandable up to 22 blades
Posted : 15/09/2014 7:07 am
Wow daming blades...sana matapos na.
But wait I can see 2 drill presses at the back...one is not enough Joey?
Posted : 15/09/2014 9:45 am
I made the mistake of buying a cheap 200-watt drill press. It did not perform as well as I thought it would. After maybe a year I bought a real drill press from VicSteel. Its 3/4 HP PowerCraft with 16mm capacity.
The small one is gathering dust. I'm thinking of what to do with it. A DIY lathe?
Posted : 15/09/2014 10:09 am
at 200W baka kulang sa power...maybe a DIY scroll saw.
Posted : 15/09/2014 10:35 am
A very practical way in storing those circular blades bro joey !! Great idea just under the
TS mobile base for easy reach. Just need now some staining and varnishing or perhaps
spray painting to avoid wood borers (bukbok).
What do you think bro ?
:2thumbsup::cool01::clap:
Posted : 16/09/2014 3:08 pm
Yes, rosy. This will be painted to protect the plywood.
I'll do the painting in the end after everything is in place. But that will take a while (2-3 more months?)
Maybe a quick coat of sanding sealer will do while waiting for the final finish. This weekend siguro. 🙂
Posted : 16/09/2014 5:18 pm
Not-so-recent updates:
Made some 1/4" x 1/4" strips of pine (its what I have available)
Glued and nailed to the sides of the router bit drawer
Cut some pine boards
Stacked them up and drilled 1/2" holes. The drill press was set to the slowest speed (I previously used it for drilling metal)
Posted : 02/10/2014 11:46 am
Uhgly! Even the boards underneath have tear-outs!
Tried again at max speed. Much better results.
Posted : 02/10/2014 11:48 am
Glued a backer board
Cut rabbets around
It fits!
Glued dividers so the panels don't slide about
Posted : 02/10/2014 11:51 am
Test fit
And I have a convenient holder for the bits that I will need for a specific task
I used plywood for the backer board. Plywood is known to encourage the formation of rust when iron gets in contact with it. I'm going to minimize the risk by applywing candle wax to the holes
Heat gun to melt the wax
Posted : 02/10/2014 11:52 am
Page 5 / 6
