DIY projects!
12 Users
liteace
(@liteace)
Re: DIY projects!
looking forward dun sa upgrade! 🙂 how much yung connectors chief? 🙂
dko lang alam sir kinuha ko lang sa air compressor 😀
Posted : 28/09/2012 6:45 pm
(@vrcinfo)
Re: DIY projects!
Hi Bro,
Hindi kaya maliit ang container mo? kasi ginawa ko ito sa FX diesel ko sa lakas ng pressure (30psi) naitatapon pa din ang langis sa intake manifold. Kaya naghahanap ako ng mas malalim-lalim na container.
Posted : 28/09/2012 11:36 pm
Re: DIY projects!
This could also work...
Posted : 29/09/2012 4:47 am
Re: DIY projects!
Parts are available in any Hardware store or DIY shacks like ACE or True Value. All you need are the following...
AIR & OIL SEPARATOR....
AND SOME FITTINGS....
WHAT DO YOU THINK GUYS, OK BA SYA?
Posted : 29/09/2012 4:51 am
Re: DIY projects!
pinaka easy...
pinaka ok !!!:no1:
Posted : 29/09/2012 8:18 am
liteace
(@liteace)
Re: DIY projects!
Hi Bro,
ayos lang nmn sir malaki naman ginamit ko
eto ung ginamit ko sir 🙂
Posted : 29/09/2012 9:46 am
Re: DIY projects!
Palupit ng palupit na ...
Oil-Catch-Can-DIY"> http://forums.vwvortex.com/showthread.php?3248273- Oil-Catch-Can-DIY
http://honda-tech.com/showthread.php?t=757695
For costing comparison ... aftermarket parts
http://www.ebay.com/sch/i.html?_nkw=oil+catch+can
eto mga 1.5K landed price Metro Manila
http://www.ebay.com/itm/JDM-CAPACITY-BILLET-ALUMINUM-RACING-OIL-CATCH-RESERVOIR-TANK-CRANKCASE-CAN-BLACK-/350609210427?pt=Motors_Car_Truck_Parts_Accessories&hash=item51a1effc3b&vxp=mtr
Posted : 29/09/2012 4:07 pm
liteace
(@liteace)
Re: DIY projects!
DIY buffing,
engine cover ng aking 1982 pantra 😀
Posted : 29/09/2012 7:50 pm
archie013
(@archie013)
Re: DIY projects!
hindi po ba mahal na din ung air/oil separator na ganito? any idea how much? 🙂 bka lng po katulad n ng prsyo nung mga oil catch can na nabibili sa tuner shops - un nga lang mas matibay siguro tong separator kasi designed siya for industrial use sa compressor hehe
Posted : 29/09/2012 11:36 pm
(@vrcinfo)
Re: DIY projects!
That's an excellent idea Bro. I'll try to check that out. Thanks.
Posted : 30/09/2012 10:12 pm
archie013
(@archie013)
Re: DIY projects!
Mitsubishi Badge Restored!
Restored this OEM badge to its former glory! 🙂
Disaster struck halfway through this project - see what happened at http://yesyoucanarchie.blogspot.com/2012/09/mitsubishi-badge-restored.html
Thanks!
Posted : 30/09/2012 11:43 pm
Re: DIY projects!
The air & oil/fluid separator is originally designed to work higher than 30psi air pressure. It's the ideal catch can and it comes in different filtering media. The smallest I got w/c i bought from WILCON DEPOT cost me around PHP 300 only. The fittings range from 35-65/ per piece. The clamps cost P10/a piece. If you want to order new hoses use the hydraulic type for air conditioners assuming your old hoses are to be replaced.
Posted : 30/09/2012 11:59 pm
archie013
(@archie013)
Re: DIY projects!
LANCER PROJECT: FINISHED!
Finally done with my "rejuvenation" project! 🙂
I've also decided on what to name her! Check out more pics at http://yesyoucanarchie.blogspot.com/2012/10/lancer-project-finished.html
Thanks!
Posted : 03/10/2012 1:04 am
archie013
(@archie013)
Re: DIY projects!
Replacing a VW Carburetor's Main Jet
With gas prices fluctuating (er spiking) almost every week. This should make my bug more economical!
http://yesyoucanarchie.blogspot.com/2012/10/replacing-vw-carburetors-main-jet.html
Need to test if the carb's efficient enough - see how on my next post! 🙂
Thanks!
Posted : 12/10/2012 4:46 pm
archie013
(@archie013)
Re: DIY projects!
Makeshift Fuel Tank/Can (to check fuel consumption)
Time to check Voxy's current fuel consumption!
See if my new main jets worked at http://yesyoucanarchie.blogspot.com/2012/10/makeshift-fuel-tank-to-check-fuel.html
Posted : 16/10/2012 2:06 am
Page 5 / 7
