DIY projects!
12 Users
archie013
(@archie013)
Re: DIY projects!
How to Replace a Scooter's Rear Brake Shoe
Safety first!
Fixed Max's rear brakes. Removing my scooter's rear wheel is easier said than done but with some guerilla tactics - I was able to do so - Read about it at http://yesyoucanarchie.blogspot.com/2012/10/how-to-replace-scooters-rear-brake-shoe.html
Thanks!
Posted : 23/10/2012 2:43 am
archie013
(@archie013)
Re: DIY projects!
Not All Plugs Are Created Equal (Attending a Sparkplug Seminar)
Learned a lot about sparkplugs recently!
Referring to the table above, when do you think you should replace Racing Plugs? 🙂 Post your answer in my FB page if you like 🙂
Read more about sparkplugs at http://yesyoucanarchie.blogspot.com/2012/10/not-all-plugs-are-created-equal.html
I would appreciate it if you could drop by and visit (also "like" hehe) my facebook page - http://www.facebook.com/yesyoucanarchie
Thanks!
Posted : 26/10/2012 1:33 am
liteace
(@liteace)
Re: DIY projects!
Referring to the table above, when do you think you should replace Racing Plugs? Post your answer in my FB page if you like 🙂
Thanks!
ito lang katapat ng Iridium sp, sidegap sp lalagarihin lang ung dulo ng mumurahing sp .
Posted : 26/10/2012 6:27 pm
Re: DIY projects!
hey archie, i am a fan here...
waiting for your DIY oil change...
what's the best oil filter wrench na mai-recommend mo ?
planning to change my cars oil filter.
many recommends that if your using synthetic oils, is you change your filters on the mid intervals of your oil change...
say, if you change oils every 10k, then you change your oil filter every 5k...
nga pala, baka mabasa na rin ito ni bro jayL, i know he to is the best man for the job... baka may ma-recommend ka na rin...
best type of oil filter wrench and where to find...
thanks and more DIY projects !!!
Posted : 27/10/2012 6:20 am
archie013
(@archie013)
Re: DIY projects!
hi sir jonathan - thanks for your kind words - coming from a senior handyman like you - I really appreciate it :thanks:
Sa wrench po - ang ginagamit namin is yung lumang oil filter wrench ko... KYK po ang brand na na chain type (parang may kadena ng motor ung wrench) - pero we only use the wrench pag talagang mahigpit na yung oil filter - often times kasi nadadala lang "sandpaper method" yung removal - parang medyo ibabalot mo lang yung sandpaper sa oil filter tpos pag twist ng malakas sumasama na siya (specially useful for tight engines na nakatago yung oil filter)... 😀 pero kung papipiliin ako ng oil filter wrench - I'd probably go with Buffalo tools - tested ko na na matibay eh.. medyo pricey nga lang hehe
As far as synthetic oils are concerned - I don't use them po eh 🙂 Medyo too expensive for my budget hehe pero sabi nila mas matagal daw yung interval ng change oil. What I use is yung castrol na asa white na lalagyan - pag may budget - change every 6 months - pag wala - at least once a year (sabay sa rehistro hehe) - so far so good naman ang performance nung makina.. 🙂 antay din tayo ng comments from those who are using synthetics - worth it kaya talaga? 🙂
Hopefully, I get the time (and money) to do an oil change soon hehe.. thanks!
Posted : 29/10/2012 1:20 am
archie013
(@archie013)
Re: DIY projects!
sir paexplain ng ginagawa dito - tried and tested mo na - ano po benefits pag nilagari? di kaya delikado? thanks for sharing!
Posted : 29/10/2012 1:21 am
archie013
(@archie013)
Re: DIY projects!
Change Oil - Toyota 4A-GE Engine (Push Works)
Sir Jonathan - here's the DIY oil change you've requested. Fortunately, my friend's car needed one! 🙂
See how he did it at http://yesyoucanarchie.blogspot.com/2012/11/change-oil-toyota-4a-ge-engine-push.html
Thanks!
Posted : 04/11/2012 1:34 am
 adzz
(@adzz)
Re: DIY projects!
Bro Archie ,
Good job in doing your DIY oil change , I also have done my own oil change in my previous ride , a 97 galant hehehee
But I noticed that you used compressed air in pushing out the remaining oil? As what I have learned before , and maybe I can share to you also as a fellow DIYer is that ;
Do NOT do this practice , if you have time to spare ,you can drain the oil completely from the engine by letting it drip maybe overnight , ako kasi I remove the oil plug on saturday night then Sunday morning then almost the oil is drained na.
Why ? You might ask, kasi po compressed air po will try tforce out the oil but mapupuwersa rin yung oil na sumiksik sa mga oil seal thus causing busted oil seal then magkakaroon na po ng tagas or oil leakage .
This was some precautions po na Sinabi sa kin ng other mech and friends e
HTH bro ,
Btw nice blog
Keep it up bro , DIY all the way hehehe
Posted : 04/11/2012 8:21 pm
archie013
(@archie013)
Re: DIY projects!
hi sir adzz.. thanks for the reminder.. good car you have there - 97 na galant - yan ba yung 4963 makina? astig! 🙂
hindi naman namin nilakasan yung hangin sa compressor.. naisip ko din sir - since yung hinahanginan is yung valves area - di naman siguro masyado malakas yung pressure enough to break the seals? what do you think? pero we really can't be too sure/too safe hehe 🙂
naisip ko din po chief kung iiwan yung drain plug overnight - di kaya mapasok ng moisture un pag gabi kasi mahamog? (baka paranoid lng din ako hehe) or maybe better if we drain it sa umaga tpos plug sa hapon.. hehe what do you think?
Since you're also into DIY - maybe you could post your projects here din (if you have the time). we would love to see it.. Thanks for reading my blog! Appreciate it!
Posted : 06/11/2012 9:02 pm
(@sam_0115)
Re: DIY projects!
Sir archie hope you dont mind me na mag butt in regarding sa oil change.
From friends sa car club forums i joined, they also discouraged using compressor. Why, kasi it's because na baka hindi filtered or somewhat h2o might go inside the engine (kaya pala yung sa mga gas stations me filter akong nakikita na basa sa hanginanan nila). what they do is to drain it overnight (naka tilt pa nga yung pagkajack! Me banlaw method pa yun using monograde oil) para simot ang langis, which in my opinion, di naman talaga 100% na ubos ng lumang oil. Kung ganun gusto natin, eh di baklasin natin engine saka linisin di ba?
Anyway, with regards to h20 topic, you maybe right if overnight draining, pano nga naman yung moisture since nakabukas makina, baka same din when using compressor.
Well, just a thought, di naman seals yung alam kong (based sa nalaman ko) ang concerned na affected) kaya ayw pagamit ng compressor, it the water kung hindi filtered na maigi.
Sorry, ako mismo nagcomment but im also confused right now haha! Just sharing lang din kung ano yung knowledge na nakuha ko.
But if we want to be specific, siguro actual tests with measurements lang talaga makaksagot regarding sa topic na yan. Not to mention yung lugar where the test will beconducted kasi malaking factor din yun. Ibakung gagawin natin yung test sa city, iba din kung sa province na mabundok.
In my opinion, basta gawin lang natin religously yng maintenance sa oto natin and we will be safe. Lalo na kung daily driven lang naman yung oto compared sa pang resing resing 😀
Posted : 06/11/2012 11:21 pm
 adzz
(@adzz)
Re: DIY projects!
Hi bro,
Yeah , it's engine is 4G63 hehehe Hataw nga yun e kaso hehehe me iba na nagaalaga dun e ,actually yun ride mo na lancer is same yun ng 1st car ko kaya nakakarelate ko sa mga DIY mo .
Hmmm as what I've experienced , ok naman di nmn napasok ng hamog ,but I think ok rin yung start sa morning then close it in the afternoon .
My pics of my DIY was in my ill fated corrupted hdd before so hehe ipon uli ko pics .
Posted : 07/11/2012 12:13 am
archie013
(@archie013)
Re: DIY projects!
@sir sam - I appreciate your comment - welcome lahat ng comments dito hehe share share tayo lahat ng nalalaman natin kasi pareparehas tayo natututo.. 😀
I totally agree with the h20 issue pag sa compressors that's why the air/water separator is a must.. kahit sa painting - and dapat drain ang compressor regularly kasi nag aaccumulate din water sa loob ng tanke 🙂
@sir adzz - sayang yung 4g63 na yun! pero I'm sure may bago ka na laruan hehehe... mukha mahilig ka din sa mitsubishi ah 🙂 antay namin mga DIY projects mo bro!
Posted : 07/11/2012 12:51 am
liteace
(@liteace)
Re: DIY projects!
napansin ko lang sir gumanda ung sunog ng sparkplug at nag lean ang a/f mixture.
sa motor ko palang nasubukan
Posted : 07/11/2012 9:31 am
archie013
(@archie013)
Re: DIY projects!
All Souls Day Project - Mausoleum Makeover
Honoring our dead relatives. Decided to paint their graves myself (with my mom) instead of having someone else do it 🙂
The results were not bad for half a day's work 🙂 Check out how it turned out at http://yesyoucanarchie.blogspot.com/2012/11/all-souls-day-project-mausoleum-makeover.html
Thanks! 🙂
Posted : 09/11/2012 12:53 am
archie013
(@archie013)
Re: DIY projects!
Jumpstarting A Stalled Car with Battery Cables
Finally got to test my extra long jumper cables! 🙂
See how Voxy helped in jump starting a stalled car! 🙂
http://yesyoucanarchie.blogspot.com/2012/11/jumpstarting-stalled-car-with-battery.html
Thanks!
Posted : 20/11/2012 8:30 pm
Page 6 / 7
