Electricity or LPG ...
Electricity or LPG for Cooking - Which is better?
35 Users
(@vrcinfo)
Re: Electricity or LPG for Cooking - Which is better?
My Imarflex Induction cooker I bought March 2012 got defective. Displaying an E6 error and the glasstop came off. Its silicon glue gave way. I bought it for P3,048 then and the price is still the same today. Luckily I had its warranty extended, so I'll have it replaced with a brand new unit again. For my second unit I bought a kyowa brand for P950 only. The only drawback i encountered is its minimum setting is 400W. Its way above our minimum cooking setting of 150-200W. We'll just have to adjust the way we cook. My observations on induction cookers are remove your pots as soon as cooking is done. never leave the pot when hot on top of the glasstop, the plastic body at the bottom of the glasstop tends to melt on prolonged heat, when cooking is done turn off using the on/off button and wait until the cooling fan stop before unplugging. This will cool-off the body and circuitry. Always unplug when not in use. The circuit is sensitive to power surges and gets damage easily.
Posted : 07/03/2013 5:16 pm
(@vrcinfo)
I've found cheap cookwares that works with induction cookers. At Waltermart's Japan Home Depot. Their pans are made of ferrous metal. I thought this is a good alternative then buying those expensive cookwares for induction cooker. To double check it just grab some of their magnets on sale and stick it to the cookware. If its magnetized then surely it will work for induction cooker. Price is less than P100, glass cover sold separately for the same price. Tried it already and cooks just fine.
Posted : 22/03/2013 10:41 am
GraceEarle
(@graceearle)
Hi, I love to cook, I can recommend you an excellent cuisinart air fryer toaster oven, you can view it here https://bestairfryer.reviews/cuisinart-air-fryer-toaster-oven/ .This air fryer can cook a variety of dishes using only electricity, I think you should like it if you like french fries.
Posted : 21/03/2019 6:17 pm
(@folomohia966)
Ultra Labs Keto the load For her: Do not try to shed pounds quick. the ones kilograms you have got misplaced too quick worst consuming behavior to your waist although every body have proper intentions, every now and then it appears that hunger resulting from surfeit is a trap for which we've got no longer even thought about. even if our food and diets are properly deliberate, starvation is stronger than us. but, if we want to shed pounds, we have to learn how to alter our body to the. https://pilpedia.com/ultra-labs-keto/
Posted : 08/04/2019 2:28 pm
Kathaleen
(@kathaleen)
Just because fire, using LPG, is directly under your pot does not mean that heat from such fire are not wasted. In fact, you can put your hand near it and feel how heat are wasted just as much as those used up in the pot. That chemical energy of gases being converted into heat energy through combustion is also wasted during such process of conversion(as in LPG megajoker), just as elecrical energy wasted when converted into heat energy (as in electric stove) because both have to contend with some heat transfer dynamics, from heat source to the pot and food in it, not to mention losses in the generation of both medium. LPGas are lost in refilling a tank, in transporting, or while in storage, just as electricity are lost in transmission, in transformers, in faulty connectors, etc.. Both have their advantage/disadvantage but the question is whether which one can better serve modern man.
Posted : 04/05/2019 12:57 am
Page 5 / 5
