How to oil electric...
How to oil electric fans
27 Users
Re: How to oil electric fans
as far as i know modern fans has self oiling system. Correct me if i'm wrong mga ka phm.:thanks:
true that, the bushings of later model fans use a self oiling brass material the only reason they become loose is when the fan does not get much cleaning dust particles lodge in the bushing causing a tighter fan turn until eventually the bushing loosens.
Posted : 29/09/2012 4:59 am
archie013
(@archie013)
hi.. sharing my DIY project para sa interested sa pagpapalit ng bushing sa fan - I did this a while back and it's easy to replace most bushings - pero oftentimes - before ako magpalit ng bushing - I use WD-40 muna - pansamantala.. pero a word of caution - once the shaft gets stuck - usually burnt oil sticks and causes the shaft to seize - it could burn your motor/fuse.
yesyoucanarchie.blogspot.com/2011/12/how-to-fix-electric-fan.html
Posted : 01/10/2012 10:42 pm
(@ericks)
maraming salamat sa napaka detalyadong inpormasyon...God bless..
Posted : 11/05/2013 7:01 am
(@yrreg)
It used to be the bushing needed replacing, nowadays as I have observed it is the rotor shaft.
If you can get to Arayat at the Cubao junction of EDSA and Arayat in a side street on the wet market side of EDSA parallel to EDSA and ask around, there is a guy there outside a small shop supplying fan parts, he fixes the stuck fan by replacing the rotor shaft, and you pay the shop as of last month, 150 pesos only -- and you can choose to give a tip to the repairman.
This repairman has a missing right hand that is why he covers his right wrist with a small towel as he works.
Yrreg
Posted : 21/04/2014 5:46 am
(@may25)
Pano po maayos ung maingay na electric fan
Posted : 10/05/2018 9:30 pm
May I suggest that you bring your fan to a repair shop so a technician can examine
the cause of that noise, may it be mechanical or just some needed cleaning or
possibly some oiling or greasing. Mura lang yan kung walang sira. :cool01:
Posted : 16/05/2018 1:15 pm
Page 3 / 3
