[Sticky] All about DIY Concrete Mouldings
24 Users
Re: My DIY Concrete Mouldings Creation
congrats Oz as this thread is now sticky...
Posted : 17/02/2011 10:46 pm
Re: All about DIY Concrete Mouldings
thanks Master Timb.
ill post the procedure as soon as i finish my welding project so others like Rosy can start making their own concrete mouldings. 🙂
Posted : 17/02/2011 10:57 pm
I'm sure a lot of members constructing houses will benefit from this thread. Even if they are not the one doing the actual work. Go go go Ossie.
Posted : 17/02/2011 11:06 pm
Go Go Ossie congrats bro we will wait your procedure making of concrete moldings how about actual training EB na ba tayo sa inyo:phehehe
Posted : 17/02/2011 11:16 pm
thanks Master Timb.
YAHOOOOOOH, finally I can see the light at the end of the tunnel, finally matutuloy na rin step by step tutorial ni sir ossie. Sana aside from your tutorial pics mag actual demonstration ka sa next EB. Iba kasi ang effect pag actuall na ginagawa at nakikita.;)
Thank you, thank you at thank you sir ossie.
I'll wait for your tutorial pics, wow excited na ko. he he he he:p 8)
Posted : 18/02/2011 10:04 am
@rosy/guys,
you can start now looking for the wood moulding designs in the internet in preparation for your concrete moulding builds 🙂
Posted : 26/02/2011 12:24 am
as per request heres the procedure for creating DIY Concrete Moulding
ok, lets see how long I will finish the 12 inch concrete moulding.
Start time:
Materials:
Moulding template. This is my very first template creation so I decided to use it as a model in creating this moulding procedure.
The small template below is for rough cement before applying the pure cement.
The bigger template is for finishing using pure cement.
The thinner the pure cement is for finishing, the better. Thicker is subjective to cracking.
Posted : 26/02/2011 6:32 pm
The template size:
Water spray
Of course:
Table with angle bar as a guide, and table top with gi sheet
Posted : 26/02/2011 6:34 pm
Cement and sand:
Making guide using softstone 😀
Planning to make 10” long moulding
Put sand.
Posted : 26/02/2011 6:39 pm
And spray with water.
It needs to be something like this. Why? The shallow part – on this part you will put cement for wall fastening.
Cement and sand prep.
Posted : 26/02/2011 6:41 pm
Put mixed cement and sand inside the measured guide.
Forgot to put 2 pcs 4mm corrugated metal, something like this, pls see below:
Posted : 26/02/2011 6:43 pm
Its gliding time.
Time check:
Pure cement prep
Posted : 26/02/2011 6:45 pm
Change the template to finishing template.
Yummy!!!
Posted : 26/02/2011 6:46 pm
First pass, using 6011, ooopppssss!!!
Second pass:
Glide:
Posted : 26/02/2011 6:48 pm
Repeat the procedure:
Posted : 26/02/2011 6:49 pm
Page 3 / 6
