Disenyo para sa isang Simpleng Garahe ng sasakyan atbp.
4 Users
Re: Disenyo para sa isang Simpleng Garahe ng sasakyan atbp.
[COLOR="red"]Well bro miked, based from the previous pix posted and this one, I suppose you have already an idea how you will attack your roofing plan. If you will have the time and patience to fabricate the beams and trusses one by one, then maybe you'll be saving on labor cost.
[COLOR="Red"]Since you said your tita might get the space back in the future, I guess this should be your base
for your post so when the time comes to remove it, your posts can easily be removed by
un-screwing the nuts.
:soccer:
Posted : 14/10/2014 8:39 pm
(@miked)
ang tanong po e: advisable nga ba talaga yung ginamit nilang spacing between trusses, which is 3 meters, kagaya nung nasa litrato?
Posted : 14/10/2014 9:29 pm
As long as they are well supported, welded and properly braced, hindi na gagalaw yan .
3 mt X 6 mt space is not really that big and top load will not really be that heavy but then if
you are in doubt of the 3 meter space between the trusses, mag consult ka na lang sa isang
neighborhood structural engineer or architect.
Good luck !!
;):soccer::rolleyes:
Posted : 14/10/2014 10:34 pm
kapatid na mike,
me project ako before sa province...carport for 2 cars (pede din 3 compact cars)...
in fact andito ako sa province now...picturan ko at post ko later...
naka 40K din ako....tipid na yun ha! recycled na yung roofing...plus me paint na din yung roof...
4" pipe GI ang ginamit ko...
halos 12" ang itinaas ng flooring...tambak ng 7" plus 5" thick concrete floor.
happy with the build.
Posted : 15/10/2014 7:03 am
(@miked)
kapatid na mike,
abangan ko yan doc! salamats....so bale approx 25k ang budget na kelangan. pero for further confirmation pa ayon sa prices ng bakal samin.
Posted : 15/10/2014 8:06 am
eto napo ang mga pics...
1.5" angular bars ginamit ko...total of 3 trusses....matibay naman...4 years na sha...ok naman ang headroom na 9feet...medyo mahal lang yung insulator na 10mm double sided...3,300petot din isang roll..naka 1.5 roll ako..malamig! besides protecting the angular bars from the GI roof moisture.
me kulang pa akong gawin pero makapal din yung pipe na nabili ko sa surplusan...almost 3mm thick kaya hindi ako worried masyado pero balak ko ikahon sha ng 4 x 4 concrete with sloping edges...nakabaon yung pipe ng 14" na may paa...at binuhusan ng concrete...pero meron nang concrete flooring na nauna para sa footing.
sloping yung pag akyat...mga 22" din lapad...
yung bubong, 3feet overhang sa harap at 18 feet sa likod...
swak ang pick up me sobra pang 6 feet sa bandang likod kung saan me lababo...
hope this helps
Posted : 15/10/2014 8:14 am
(@miked)
malaking tulong talaga yan para sa akin sir dahil torn between 1.5 and 2 inches ako sa roof truss e. kelangan ko lang ng magreferee at kayo po iyon. hehe.
hmmm....pwede na rin kaya sabitan ng chain hoist yan? hihihihi....joke lang. included sa initial plan ko ito kaso baka tatanggalin din e gagawa na lang ako siguro ng hiwalay na movable frame for that.
maraming salamat sir.
Posted : 15/10/2014 8:24 am
(@miked)
:soccer:
exactly sir rosy! ako na ang gagawa nung roof members dahil kahit papano e enough na rin yung metalworking tools ko. kelangan ko lang ng konting dagdag pa with regards to the carpentry tools pero minimal lang naman.
learning experience na rin ito para hindi parating dependent na lang sa mga karpintero, fabricators, etc.....syempre hanggang sa mga ganitong klaseng type lang ng project ang kaya ng powers. kung buong bahay na yan e civil engr/architect na kukunin ko.
Posted : 15/10/2014 8:49 am
(@miked)
so far eto na rin pala ang nakuha kong agromet data galing sa mga libro kong maalikabok:
Mean annual prevailing wind direction: NORTH
Wind Pressure: 30 pounds per square foot (psf)
Ave. Wind Speed: 10 kmh (kaso walang kwenta na ito pagdating ng bagyong malakas):twister3::twister3:
may science pakong nalalaman.:rolleyes::english:
Posted : 15/10/2014 8:55 am
