[H] Paano po pagpaint ng wall?
25 Users
Re: [H] Paano po pagpaint ng wall?
well, some people are bent on using one product over another for one reason or another. we are open to all opinions and options. maybe you can post your painting schedule of your choice of materials too.
having choices is what the forum is all about anyway...
Posted : 07/07/2010 1:11 pm
An alternative (for new concrete only) that doesn't need all the many steps and associated waiting time would be mineral paint. No neutralizer, no washing off, no primer coat. Just apply the recommended number of coats of mineral paint directly on the cured concrete.
Supposedly, mineral paint would be 'breathable', instead of sealing, which could be an advantage when there is potential for trapped moisture problem. Also has a different look/texture than impervious coatings that some may find appealing.
Not saying better than conventional paint, just an option to consider.
Posted : 07/07/2010 7:27 pm
(@angelo)
Good day sir!
If new concrete, kailangan ng 14 to 28 days na curing time bago tayo magpintura. (Kailangan ito para lumabas ang alkalinity ng semento at maiwasan ang mapa-mapa pag nag-apply na tayo ng pintura.)
Tapos nito, pahiran ng Boysen Masonry Neutralizer #44 para lasunin ang semento. Huwag purong neutralizer and ilagay. Kailangan 1:16 lang ang ratio ng neutralizer sa tubig. (Halimbawa: 1 litrong neutralizer sa 16 litrong tubig)
Patuyuin overnight. Mapapansin mong merong mga white crystals na lalabas sa walls mo next day. Ibig sabihin nito nalason na ang konkreto.
Alisin ang asin (white crystals) sa semento sa pamamagitan ng tubig. Pag natuyo na ang semento pwde na tyong maglagay ng pintura.
1st Coat: Boysen Flat Latex #701
Putty: Boysen Masonry Putty (masilya)
2nd & 3rd Coat: either Flat Latex, Semigloss Latex or Gloss Latex
PWEDE RIN
Kung ayaw nang lasunin pwedeng gumamit ng Acrytex Primer instead of Flat Latex bilang primer. Pero kailangan pa rin ng curing time na 14 to 28 days bago magpintura.
Sir, your post is so informative. Ngayon ko lang nalaman. My questions are.
1. Bakit po wala na yong primer? Diba po pag unang pintura is primer o yon na rin yong 1st Coat: Boysen Flat Latex #701?
2. Paano po kaya i-repair tong concrete wall dito house na parang ang ipinintura pa lang is primer, 1st coating lang sya. Pwede na po ba etong patungan ng 2nd coating up to 3rd?
Thank
Phils. Exam Resuts - www.examresultsph.com
Posted : 10/08/2010 11:46 pm
opzuk4x4
(@opzuk4x4)
Flat latex paint is the commonly used primer for interior applications.
GACA CONSTRUCTION
Posted : 13/08/2010 9:13 am
(@euqihn18)
mga bosing maki tanong na nga rin po ako as we also plan to diy yung pagpaint ng walls nmin...yung neutralizer ba ok lang abutin ng 1 week before mahugasan or nid tlg na 3 to 4 days lng e mahugasan na sya agad? may effect po b un if ever abutin sya ng 1wik before matanggal yung mga white cyrstals? every weekend lang kasi kami makakapunta ni hubby sa house nmin e... pa-advise nmn po ako. atleast lng may idea kmi...thank you thank you
Posted : 23/09/2010 5:58 pm
clayfigur
(@clayfigur)
To be honest, its Ok. The concrete neutralizer, only works by removing alkali build up by using acid. (normally weak acid, if it is strong they recommend you to add water in the label). If it is already neutralized, the alkali in your wall will not attract moist that may damage the paint.
Cement is naturally humectant in nature, it attracts moist in the air, making your wall perspire.. This is bad for your paint, it will strip off your paint from the wall, that's why curing or neutralizing is important.
Posted : 01/02/2011 12:41 am
(@euqihn18)
ah ok....kwestyun po ulit. need po ba talagang lasunin muna ang concrete wall kahit matagal na siyang naitayo like more than a year na? or pwede na siya primer agad kung ganun nakatagal? anu po ba ang magiging cause ng hindi pag lason ng wall kahit matagal ng naitayo? thanks in advance po
Posted : 04/03/2011 3:42 pm
i would suggest to neutralize it, even after a year old or so na ang concrete.
i have experienced cracking of paints in some areas when we did not neutralized the concrete even after a year or so old.
para hindi na maabala, better to neutralized since madali lang naman i-apply ang neutralizer, and let it stay for 24 hours at least before applying the primer.
Posted : 04/03/2011 5:26 pm
correct me if i am wrong but after i have applied the neutralizer, i let it stay overnight or upto 48 hours and wash off the white flakes (by scrubbing or by pressurised water hose)...when i feel the wall is completely dry from all the cleaning i then apply the primer.
in one Ace paint label, i read that a month old concrete need no neutralizer anymore and should be ok with the first coat of primer..i am talking about my favorite Stain Halt by Ace. (does the acid in the cement eventually wear off? i dont know...)
and thankfully recently paint companies came up with a bright idea of these siliconized paints acting well as a moisture barrier...i just make sure i painted the exterior wall twice of the same paint before i do the interior...
but hey guys, if there is a better way than what i know please share it then.
(coz painting walls are the things i enjoy most in DIY weekends);)
tia
Posted : 04/03/2011 6:45 pm
(@euqihn18)
thanks for the inputs sirs...i also asked others opinion about the same matter and yes, they said that if its already a year, then we can actually put primer directly to our wall even without having it neutralized and to violaine, quite curious lang po coz if this stain halt by ace shows the same on its label while others don't...uhmmmm di po kaya possible lang siya for this particular brand? :confused:
Posted : 04/03/2011 8:09 pm
@euqihn18, I used Nation N1540 flat latex to prime my un-neutralized interior walls. Makapit naman siya. A 16-liter pail is about P1,100 at my suking hardware store.
Posted : 04/03/2011 8:15 pm
[HTML]quite curious lang po coz if this stain halt by ace shows the same on its label while others don't...uhmmmm di po kaya possible lang siya for this particular brand?
[/HTML]
could be...stain halt is relatively expensive kasi (but can be used to primer wood, metal and bare concrete but specifically for wood to cover nail heads with the tendency to corrode and stain the paint) ...there are suitable cheaper products locally available at any hardware or home depot that are intended to primer a concrete wall and i believe the right way to go.
iirc, these newer acrylic latex paints can be used as a primer already.
like joey said, usually the paint label will recommend the brand's primer paint and should be followed for best results.
Posted : 04/03/2011 9:25 pm
(@patdoll)
hi po ng rerent lng kasi kmi gusto ko sana ie paint ang room namin pwde ba kahit wala ng neutralize diritso paint ng white tpoz sunod na ang gusto mo na kulay salamat po
Posted : 09/05/2015 11:10 am
geneakizuki
(@geneakizuki)
Just a question sirs, my walls are already painted white and have no way of knowing kung anong pintura ginamit ng developer. Gusto ko lang palitan ng kulay, pwede ko na bang iskip ang pagpriprimer at direkta ko ng pinturahan ng type kong kulay?
Posted : 15/05/2015 5:55 pm
(@phodietr)
Yung pag primer ng wall mo sure ako d mo na kailangan kc may pintura na now ang concern mo kung pwede na patungan yes pero kailangan mo medyo lihahin ng 200 grit pero para lang magasgas ang pinaka ibabaw para lang medyo pero hindi mo ba bakbakan yung paint nya ngayon para lang hindi makinis ibabaw ng paint para kumapit ng maganda ang ipapahid mo na bagong paint ang chaleng lang naman dyan pag enamel ang gusto mo ilagay sa wall mo kasi baka elastomeric or latex ang naka lagay ngayon pag kasi elastomeric or latex ang original na Naka paint tapos papatungan mo ng enamel dun magkaka problema malamang kumulobot yung ipapatong mo na enamel pero kung elastomeric paint ipapahid mo dka mag kaka problema kahit pa enamel o elastomeric ang nakalagay na dati
Posted : 13/06/2015 8:06 am
Page 2 / 4
