Wood Parquet Q
10 Users
(@Anonymous)
Re: Wood Parquet Q
There may still be some moisture wicking up, like the wick of a kerosene burner. If I were you, I'd lay a laminate floor. The foam under the laminate forms an effective moisture barrier.
Posted : 25/08/2007 5:22 pm
(@gonefishing)
Re: Wood Parquet Q
sir gonefishing,
salamat po sa inputs, tanong lang po sir saan/ano po b yung project unlimited?shop po b?location po?any websites?
contact no po?
maraming salamt po uli!
I think they have branches in QC, but I went to their head office in binondo, anyway ito number nila 2438888-95
Posted : 26/08/2007 2:00 pm
(@portugalbear)
Re: Wood Parquet Q
I plan to remove my parquet flooring and replace this with laminated flooring. My question is what to do with the old parquet tiles? Can I sell this?
Posted : 26/09/2007 2:41 pm
(@ruel_g)
Re: Wood Parquet Q
Ano po tawag sa pandikit sa wood parquet?plan ko kasi gumawa ng mesa,gamit ang palochina and plywood.wood parquet style.tnx
Posted : 30/08/2012 9:34 pm
Re: Wood Parquet Q
Brad, STIKWEL ang name ng brand, its a wood parquet flooring glue that can be purchased at most ordinary hardware stores. If your project table will not be that big, you can buy 1 or 2 small yellow plastic containers of Stikwel of 500 grams each , or maybe add more depending on usage or buy a bucket full.
Posted : 31/08/2012 9:28 am
(@ruel_g)
Re: Wood Parquet Q
Yung stilkwel po ba na glue?yellow yung contaINER
Posted : 31/08/2012 8:21 pm
(@jun-dela-pena)
Hello po, first timer here sa forum. We're about to add a living unit as a second floor. Plywood po ang subfloor on steel framing. Can i do an overlay of tiles sa plywood? Any suggestions po sa installion method. FYI Baguio po location, need to consider high humidity 🙂
Posted : 24/11/2017 8:23 am
Maybe you need to screw or nail some 1/4" or 1/2" thick Hardiflex on your plywood
so to make the tile cement adhere to the Hardiflex surface.
Or better consult an architect just to be 100% sure.
Posted : 28/11/2017 1:51 am
