MDF furniture
22 Users
(@roberttokyo)
Re: MDF furniture
I am new here. Just red the posts about MDF. Do u know what do they called the partition they are using in the public CRs. It looks like it is waterproof. I dont think it is MDF. I was trhinking of using it in making kitchen cabinets. Is it good yo use it for cabinets? Thanks for the help.
Posted : 10/01/2010 10:21 pm
Re: MDF furniture
Hi Robert. Its mostly mdf if i am not mistaken. If not then it would be laminated marine plywood. You can have marine plywood and have it laminated ( a little bit tedious). Then cut to size and just finish the edge with edge banding with the same color as the laminate used.
Besides mdf i have seen tiled cement and granite for those partitions.
Posted : 18/01/2010 4:43 pm
(@zedx7)
Re: MDF furniture
where do you guys buy your marine mdf/hdf?
Posted : 24/01/2010 8:58 pm
Re: MDF furniture
any hardware construction supply store has it (the marine ply not the mdf).
The larger depot type stores also has both.
Wilcon Builder Depots have it readilly available, mdf and marine ply. As for the variety of MDF they may not have all in stick but they are open for ordering.
While Ace only has it in select branches. Cant remember but their big branches has marine plywood, but not sure of MDF
Posted : 29/01/2010 5:21 pm
(@roberttokyo)
Re: MDF furniture
thanks for the info beebeenator
Posted : 31/01/2010 1:47 pm
Re: MDF furniture
they use phenolic sheets or phenolic fiber boards. and there are several kinds. the ones in the cr's use what is commonly known as phenolic fiber board and is similar to concrete in structure. very sturdy, very heavy and very expensive. cost about 7K for one sheet and that is the 12mm thickness pa lang.
Posted : 05/03/2010 1:27 pm
(@toy-01)
Re: MDF furniture
Sir meron ba pang re-touch ng MDF furniture meron kasi gasgas. thanks
Posted : 12/09/2010 5:50 pm
Re: MDF furniture
toy 01, from pdvd? welcome to pinoyhandyman sir... do you have a picture of the item in particular?
Posted : 12/09/2010 9:01 pm
(@toy-01)
Re: MDF furniture
Yup...sir try ko kuhanan ng picture tapos post ko.
Posted : 14/09/2010 12:07 am
 Neo
(@neo)
Re: MDF furniture
i am not sure if lexus has marine MDF or HDF boards. but you may try to contact anna fabricante at 3576065 / 7823046. she sent me an email of their price list on the different types of boards they are selling.
saw her info at the sulit site. just search for "mdf phenolic board". the 2 results are her ads - babymisteryosa.
http://www.sulit.com.ph/index.php/view+classifieds/id/1086810/sell+of+MDF%2C+GYPROC+gypsum+board%2C+SHERA+/+FLEXBOARD+CEMENT+BOARD%2C+MELAMINE+LAMINATED+%28mfc%29++particle+board+%26+mdf%2C+LAMINATED+FLOORING%2C+phenolic+boards%2C+metal+framing%2C+doors%2C+versa+board%2C+%28HPL%29+high+pressure+laminates%2C+edge+bond%2C+MOULDED+DOORS?referralKeywords=mdf+phenolic+board
Posted : 06/03/2011 10:57 am
(@nelson-de-leon)
Re: MDF furniture
I also used MDF as a replacement for wood sa frame ng cabinet ko. Most woods sa hardware kasi are not flat and straight. Wood also has a tendency to "breathe" so i experimented with MDF. I applied sanding sealer and gloss enamel with the purpose of "protecting" the MDF against moist.
Posted : 26/05/2011 1:32 am
(@reyesknox)
Re: MDF furniture
Medium Density Fiber (MDF) is a building material used for construction purposes. It is made by the breakdown of hardwood and softwood with resins and wax to form wood fibers.It is mainly used for making closets and drawers.
http://www.officefurnituresquare.co.uk/
Posted : 07/06/2012 3:22 pm
(@ruel_g)
Re: MDF furniture
Ano pinagkaiba ng melamine,pvc laminate at laminated wood.Gusto kong magtry ng modular cabinet e.tnx
Posted : 07/06/2014 8:38 am
