How to make white grout white again?
13 Users
(@nicomambo)
Re: How to make white grout white again?
The strongest chemical you can use is muriatic acid. If it doesn't work, nothing else will.
But be very careful when using it, and read the instructions well. Make sure the room is well ventilated, wear a mask & gloves. When rinsing, apply baking soda to neutralize it because it will rust your drain if you don't (if your drain is made of steel).
Posted : 22/05/2010 12:04 pm
(@armstrong)
Hi! I just discovered the answer and solution to all our grout stain problems. I found a product called GROUT-AIDE MARKER which is actually a marker that covers grout stains while it kills mold and mildew. I bought this at True Value in Alabang Town Center. Since i tried it several months ago, my bathroom tiles looks clean and new everyday. You may want to check out their website, just search for Grout-aide marker. The markers come in different colors too if you have tile grout other than white. Glad to be of help.
Posted : 27/10/2010 5:48 pm
(@fgvillegas)
how much does it cost?
Posted : 29/10/2010 10:46 am
(@ricky)
Thanks for the heads-up, will check it out soon
Posted : 31/10/2010 4:57 pm
Spray clorox and leave it overnight. You'll be surprise the next morning 🙂
Will it be a good surprise or a bad surprise? 😮
I used ABC sealant which i tediously applied myself just to be sure that the instruction is followed ... also I used the latest abc grout which claims as having microban in it that reduces molds and stains. Bt sadly ...
So ABC Grout Sealer is no good as a sealer and/or ABC Grout is no good? Is there any good locally available sealant and/or grout?
Which works better -- ABC Grout Sealer applied to ABC Grout, or ABC Grout Waterproofing mixed with ABC Grout? Or equally ineffective at keeping white grout white?
Posted : 31/10/2010 5:24 pm
Anyone had long term experience with this Grout-Aide? Is it a miracle cure, paint once, white forever? Or will the paint eventually become dirty again, requiring repainting over, so that if you repaint regularly, there will be layer upon layer of this paint?
Posted : 18/11/2010 10:00 pm
 macG
(@macg)
This is a great tip. I have to take note of this. Thanks. 🙂
Posted : 12/12/2010 1:05 am
