Latex paint for plywood?
27 Users
bare plywood + rj putty + any acrylic latex paint = latex painted plywood!
this is recommended sa mga items na hindi na hahawakan ng gagamit forever...katulad ng kisame...LOL
Posted : 07/10/2016 4:10 am
(@pepperpig)
i'm kinda not sure if i understood this perfectly, correct me if i'm wrong (paint noob here).. i'm renovating my room and retained a wall made of plywood, while the rest is replaced with new gypsum boards. do i prime and seal both materials with stain halt, then i can coat it with boysen healthyhome color?
Posted : 13/01/2017 12:26 am
, yes, you can prime and seal it using stain halt (now are rare entities at ACE), then coat them with any acrylic or latex paint, or even enamel...stain halt goes with anything eh.
but there are primers now for wood which can take up acrylic latex paints..i am just not sure exactly about the brands but they should be available by now..spend time reading the labels at mall hardwares..
Posted : 25/01/2017 5:20 am
(@springfield27)
Sir violaine, just want to be sure if this would work kc plywood gamit sa wall/divisions:
1st coat is to use BOYSEN Flatwall Enamel B-800
Then seal with BOYSEN Plasolux Glazing Putty B-311
2nd and 3rd coat BOYSEN Healthy Home
Maraming Salamat! - Mark
Posted : 07/02/2017 11:26 pm
(@thejay)
Hi need advice.
Anong primer for wood na compatible with acrylic latex
primer for metal that is also compatible with acrylic latex
or meron bang odorless paint for wood and metal?
TIA
Posted : 01/06/2018 10:52 pm
(@jagert)
I was looking for the paint sprayer for my garage and I found this website https://usefuldiary.com/paint-sprayer-for-home/ selling online. I hope here really good paint sprayers are sold, see, I am ordering for the first time. Here are a lot of paint sprayers that is why it took some time to choose the one I needed. So follow the link if you want to buy the one for yourself.
Posted : 12/06/2018 5:33 pm
Batang_Hamog
(@batang_hamog)
Hi need advice.
TIA
Hi thejay. I believe flat wall enamel should do the trick since its's enamel-based with a matte [almost] finish. Its even intended to be used as a primer before applying putty and top coat [as per instruction from Boysen Flat Wall Enamel]
Just sharing, not sure if this helps...
I made a cabinet a few years back. Collapsible siya and the pieces [3/4" plybpoard] are joined together by black screws. Reason for using latex is for interior only while the outside is to be wrapped in vinyl sticker. Anyways, what i did was apply flat latex as first coat, sand it, glazing putty then sand it again. Lastly I applied 2-3 coats of gloss latex. The finish is almost the same as enamel and till now ok pa naman.
Posted : 12/06/2018 7:52 pm
Page 4 / 4
