LPG Hose and Fittings?
12 Users
Re: LPG Hose and Fittings?
Where cam one source PPR3? I assume one needs special equipment for fusion welding?
Posted : 16/05/2011 8:48 pm
(@horsepower)
Most metro-manila hardwares sell PPR3. Some of our suppliers here in Luzon (are you from Luzon sir?) are Benesco in EDSA Cubao and Dexterton in C3 (dexterton.com). We bought our own fusion welder (more or less 10k street price, depending on brand, quality and performance). You can, however, borrow from the store. We used to borrow from Benesco for a 5 or 10k cash bond (refundable upon return of unit) when we still didn't have our own machine (it's very small, like a shoebox).
Posted : 16/05/2011 10:24 pm
(@tinmuning)
Any recommendations on installers for LPG pipe fittings? Would this be better than just having the LPG inside the kitchen counter?
Posted : 02/11/2011 4:30 pm
Darn. Forgot to keep track of this thread again!
Also forgot about the hose altogether! So far, the cracks on the rubber seem to be on the surface. And, to answer some old queries, my hose is inside a PVC pipe that is embedded in the wall. The tank is in a shed in the corner of a garden that is not in direct sunlight. So neither hose nor conduit is exposed to sunlight nor ambient/radiated heat.
Posted : 02/11/2011 9:36 pm
(@noyric)
PPR is a good pipe sir but not specific for LPG. I was advised not to use them unless it is for water.
There is a gas-specific (LPG) pipe sometimes available in Wilcon. I think the supplier is Unitec. This is good for longer installations. I hope this helps sir.
Posted : 18/04/2018 6:21 pm
(@ln106g)
Hi, everyone! Just finished with my outdoor counter top in my dirty kitchen. The LPG tank is under the counter located at the far side of the counter and piping used is GI pipe to bridge the tank to the cooktop. My question is where can I buy a brass nipple fitting that will link the GI to the LPG hose? this is how it looks:
the Thread is 1/2" NPT. The "nipple" is around 3/8' enough to fit snugly into the LPG hose. Thanks po
[IMG2=JSON]{"data-align":"none","data-size":"custom","src":"http://www.yashbrass.in/brass_nipples_big/brass_hose_nipples_5.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"custom","src":"http://pinoyhandyman.com/core/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw=="}[/IMG2]
Posted : 01/05/2018 9:56 pm
