Tips and Tricks Around the House
20 Users
 adzz
(@adzz)
Re: Tips and Tricks Around the House
@adzz
Correction, if one line is broken/disconnected, you would be measuring (hot) line to floating, not line to ground. The incandescent light bulb or any load test should be able to tell which is the case:
line to floating -- no light, measured voltage should drop to zero
line to ground -- bulb will light (or dim/flicker), measured voltage should stay at no-load value (or decrease but stay nonzero) ... depending on how good the ground is
Welding machine? I wonder if this kind of usage triggered the failure, e.g., overloading or heating cycles over time even if not technically overloaded.
@ sir guad ,
I'm a little confused po in doing the test that you mentioned. If it would not be too much trouble , can you possibly detail in how to test the line?
I might try to do it if time permits later tonight.
Thank you very much sir
Posted : 29/01/2013 1:58 pm
Which part not clear? The idea is to measure the voltage at that outlet with your VOM as done before but with a light bulb plugged in. You can attach wires/plug to a light bulb socket or use an existing lamp. Incandescent so that it will still 'work' and not be harmed if powered by less than 220 V. If still not clear how to do this test or how to do it safely, best to wait for the electrician.
Posted : 30/01/2013 7:33 am
 adzz
(@adzz)
my problem was solved just today.
my initial hunch was correct nga na one of the wire was cut off , but what makes it difficult to see is that yung way it was cut.
the connection was from the breaker panel yun wiring is through the conduit pipes to my wall outlet then spliced to the outlet in the garage( eto yung no power ) , yun pagkasplice nung connection papuntang garage outlet e nabroken/putol na , kaya pala na me power yung outlet sa loob ng bahay but yun sa garage wala.
in the end, i just decided to rewire the whole circuit na yun and used the gage #10 wire kasi ill be using it for my power tools and my welding machine so upgrade na lang .( thanks nga pala sa info ng wire size sir joey from cab1net kagabi )
medyo natagalan lang yun paghugot ng wires kasi , some dirt/mud yata yun nagpasikip sa wire nung pinaliatan namin ng wire di makapasok e.
,thanks po uli sa input 🙂
Posted : 02/02/2013 5:57 pm
Well bro, I'm glad to know that you have solved your problem regarding your electrical connection sa garahe. Hehehe, its, all is well that ends well. 😀 😉
Now you can continue with your wood projects .
CONGRATS BRO !
Posted : 02/02/2013 7:15 pm
 adzz
(@adzz)
CONGRATS BRO !
Thannks po sir Rosy .
hehehe pause muna , exams week ng mga kids ko kailangan gumawa pointers tsaka revisions e
pero resume yun mga gagawin ko after
thanx again
Posted : 02/02/2013 11:23 pm
My personal nightmare is having a wire disconnect or getting irretrievably snagged while pulling it out of the conduit.
I'm glad you solved this.
Posted : 03/02/2013 5:52 am
 efx
(@efx)
Buhayin ko lang po ang thread. Effective palang pantanggal ng double sided tape at liquid nails sa wall ang WD40. Yun ang ginamit namin nung nilinis namin ang wall ng room ni baby.
Posted : 02/12/2015 3:53 pm
(@boo-semi-retired)
pre, thanks for sharing this tip 🙂 ...
Posted : 03/12/2015 6:07 am
(@reytm)
Ask ko lng po kung magkano po dapat ang ibabayad ko sa mag wa wiring?
Pano po ang computation dito sa pilipinas?Salamat po...
Posted : 23/01/2019 12:17 pm
(@ducklife)
I'm quite impressed with the tips and tricks you share. Very good and extremely useful. I will save these tips and tricks.
happy wheels
Posted : 22/02/2019 12:15 pm
Conall
(@conall)
Really useful information! Thanks!
Posted : 01/04/2019 7:13 pm
(@qolomohia112)
Tevida canada pills targeted to boom libido. maximum of these merchandise percentage numerous common tendencies consisting of: made from natural substances, available with out a prescription, enhance sexual preference and require everyday use for max effect. The high-quality and effectiveness of different dietary supplements varies widely from one. https://pilpedia.com/tevida/
Posted : 20/04/2019 1:43 pm
(@tolokonia225)
Hearing x3 useful resource tailor-made to healthy in your hearing wishes and life-style. The six channel more model complements the natural sound-gathering characteristics of the ear in minor hearing loss instances. CIC however provide enhanced sound amplifiers, as well as additional functions, consisting of a smartphone transfer. some patients sense that this form of listening to aid is simpler to control. A BTE (in the back of the Ear) showcases digital features contained inside a case placed at the back of the ear. Tubes and different custom designed traits are utilized to drive sound to the ear canal. commonly presenting a robust body, this model is frequently decided on for kids with listening to troubles. This sort of listening to resource also presents improved amplification over smaller. https://hearingx3reviews.com/
Posted : 10/07/2019 2:44 am
Page 3 / 3
