All About Metal Bender
11 Users
Re: All About Metal Bender
trick:
if you are bending the same shape, you can put your “model” bent metal bar as a guide, then bend it.
Posted : 25/02/2011 11:52 pm
Here's my Bender as it stands fully operational now. Will see if I can make some jigs for it later.
Extended Handle
Posted : 26/02/2011 5:20 pm
your bender is really nice and durable, do you have plan to paint it with [COLOR="Pink"]pink color? 😀
Posted : 26/02/2011 6:58 pm
your bender is really nice and durable, do you have plan to paint it with pink color?
It could be painted where the parts are not exposed to the bending but for now I leave it as it is. When there's chance maybe I grind the welds and re weld it again but not until I get the ADH.
Posted : 26/02/2011 8:30 pm
i visited Comppact Steel this morning and bought 13.3mm x 5 inch long (Php15/pc) round tool steel as dowels for my metal bender which are bigger to what i need - 12. 6mm.
heres what i did 😮
Posted : 31/03/2011 6:14 pm
good thing, mang simonds is really tough 😀
and the finished dowels hehe
Posted : 31/03/2011 6:17 pm
after heating both ends with welding machine and soaked to oil overnight 😀
Posted : 01/04/2011 6:34 pm
test fit:
no need to put set screw as lock in the rotating arm since i tested the speaker on the bracket in full volume with no movement (no vibration) (full volume with the cord unplugged) 😀 hahaha joke
spray painting to follow 🙂
Posted : 01/04/2011 6:40 pm
I need to hang mount my 110V Electrical Cord Reel in the wall.
Will need to fabricate a bracket for it. I chose to use a flat bar that will be welded to a metal plate that will be bolted to the wall.
Bending time. 2" wide by 1/4" thick flat bar. Pure Muscle Bending ( no help from a heat source to make the metal softer ). Just an extender added to the bender's handle.
However if I wanted a sharper bend angle then application of heat on the bend line will accomplish it.
Going to upgrade the crappy hook to a bearing assisted setup. It will help make the reel follow the desired direction when the cord is pulled.
Posted : 02/04/2011 4:50 pm
whoaa!!! 2" x 1/4" thats thick! hehe interesting yang project mo ah? hehe
Posted : 02/04/2011 8:46 pm
Bender ok lang kapal and lapad .... sisiw. Kinakabahan lang ako sa vise baka bumigay.
I think the bearing approach is a bit an over kill for just a cord reel swivel.
Decided to change the design and fab a bushing type approach. Will weld all this tomorrow.
the extra friction will be an advantage here too as the swivel will not rotate as freely like if it were riding a bearing.
I wish I had a hole saw the size of the bushing to bore the flat bar bracket ... since I have none I'll use oxy ace.
http://www.amazon.com/MK-Morse-AV100-Bi-Metal-Maintenance/dp/B000E8HTPM/ref=sr_1_3?s=industrial&ie=UTF8&qid=1301754579&sr=1-3
This kit was less than $65 when it went on sale.
Posted : 02/04/2011 10:27 pm
Have you tried this double cut before. Do you think it's safe?
Posted : 02/04/2011 11:57 pm
i havent tried it yet but i think its ok, as long as the metal you are going to cut are fully grip and by slow cutting the metal.
you can add 2 more clamp for added safety 🙂
Posted : 03/04/2011 12:20 am
I was just wondering if that cut would be ok. Yeah probably smooth feeding will do the trick.
Actually I can just bend the excess edges and weld these to the plate instead of cutting it out.
Posted : 03/04/2011 2:09 am
much better, you'll save electricity, disc and the bad metal smell during cutting 🙂
Posted : 03/04/2011 2:18 am
Page 3 / 9
