All About Metal Bender
11 Users
Re: All About Metal Bender
Oz kakahiya naman sa thread mo. Metal bender thread ito kaya hindi ko na pinutol , binend ko na lang. 🙂
Meron bang 29 mm na hole saw available locally?
Posted : 03/04/2011 2:20 pm
how did you bend that? oxy?
Posted : 03/04/2011 9:18 pm
I made a cut on the bend line using a cut off wheel. Half the thickness of the flat bar. Then I bent it with the bender.
Posted : 03/04/2011 10:32 pm
i see, coz the bent part is really stiffed hehehe
you can try this, welding by weaving 😀
Posted : 03/04/2011 10:58 pm
Yeah that weld will fill the right angle bend. It's easier to weld if the metals are not totally separated thus the use of the bender.
For now since I'll be welding it to a plate I'll use the gap as the bevel.
I'll need to go buy 1/4" thick plate. The one on the pic is 1/2" and is really too thick. That's the one from the aborted bender base.
Posted : 03/04/2011 11:06 pm
(@hammer3011)
I need to hang mount my 110V Electrical Cord Reel in the wall.
Will need to fabricate a bracket for it. I chose to use a flat bar that will be welded to a metal plate that will be bolted to the wall.
Bending time. 2" wide by 1/4" thick flat bar. Pure Muscle Bending ( no help from a heat source to make the metal softer ). Just an extender added to the bender's handle.
However if I wanted a sharper bend angle then application of heat on the bend line will accomplish it.
Going to upgrade the crappy hook to a bearing assisted setup. It will help make the reel follow the desired direction when the cord is pulled.
Very nice DIY flatbar bender machine, just what I need for my project, keep on blogging!!!!
Posted : 07/04/2011 8:17 pm
(@hammer3011)
Very nice DIY flat bar bender, keep on blogging!!!!
Posted : 07/04/2011 8:20 pm
Glad you liked it. We have Master Ossie to thank for doing the research on the DIY bender. Very cost effective to build and efficient to use. 😉
Posted : 07/04/2011 11:19 pm
i did used this dowel to bend 12.7mm round bar and the dowels(tool steel) were all also bent slightly 🙁
after heating both ends with welding machine and soaked to oil overnight 😀
Posted : 08/04/2011 9:55 am
Looks like the used Rack End suspension parts from cars are stronger. I never had problems with these dowels bending whatsoever.
Posted : 08/04/2011 11:38 am
The bender has really been helpful making the custom brackets I need that I decided to give it a coat of paint. Hopefully will help contain rusting better instead of spraying the tool with WD-40 once in a while.
This color is dedicated to Ossie .... the Power of Blue.
Posted : 19/04/2011 12:36 am
Oz ayan na. Power of Blue. Magasgas na magasgas at least walang kalawang.
Posted : 19/04/2011 3:38 pm
wowow! power of blue!!! hahaha
ang ganda, for pick up na ba yan ni Ryobi? hehehe
Posted : 19/04/2011 8:59 pm
here's mine (power of the green) (green for now) hehehe
i have no plan to paint this bender since it was reheated and bathed with oil.
the green primer was just a left over from my spray painting this afternoon.
i didnt even clean the bender before i painted it 😮 its already 7pm that time, so lusot na siguro kahit paano hehehe
Posted : 19/04/2011 9:24 pm
wow!!!!! grrabeeee ang tindi ng mga bender nyo ganda ng kulay hehehe nakakaingit naman hmmm eto ang sakin materiales muna ha tapusin ko muna ung table ko maybe this week masimulan ko na ito
my wip 5 inc. long 12mm round
and i bought 1 1/4 x 1/2 thick @ 20 feet long flat bar cost P 860.00 pesos
Posted : 04/05/2011 12:32 am
Page 4 / 9
