DIY Sheet Metal Brake Press
5 Users
butch11a
(@butch11a)
Re: DIY Sheet Metal Brake Press
yun welding table ko na siguro easiest build, old narra office table para matibay and 11mm steel plate on top, with a ground connector on the side, so that everything on the table is grounded, the shelves i fill with tools and supplies ......kailangan solid wood table para matibay yun drawers....
Posted : 07/03/2012 2:37 pm
Butch ...pa post mo na rin table mo when you have time .... hehhehhe
I'll be installing a permanent ground cable din sa table ko kaya lang ina antay ko pa yung mga connectors ... sa me bandang lower legs ko na i hook up.
Bro saan pala location mo?
Posted : 07/03/2012 3:44 pm
butch11a
(@butch11a)
sample of aluminum sheet bending for a fuel cell project ....
hi jay, Makati area lang ako....yun welding table pics ko nasa kabilang thread.....
Posted : 10/03/2012 10:10 am
Here's a video of a welding table build with a metal sheet brake in one end.
This might interest you bro JayL. 😉 😎
link : http://weldingweb.com/showthread.php?p=903511#post903511
Posted : 10/03/2012 10:59 pm
(@twisted)
wow galeng sir butch11a!!! also interesting project, fuel cell:)
Posted : 11/03/2012 11:14 pm
Butch ... these bendings look great. Very functional bender. What's the thickest sheet it can handle?
Posted : 16/03/2012 11:42 pm
butch11a
(@butch11a)
hi jay, for aluminum i'm using 2mm in the pics, it can do up to 3mm aluminum, for stainless i've tried it on 1.2mm but its already pushing it, which is why i added the center brace...btw just modified the bender the other day so that the clamping bar on top would also go up as the two end bolts are turned, and added another brace on the top bar as well....
Posted : 17/03/2012 1:49 pm
(@nukehead)
nice bender
just do it work it make it!:gun:
Posted : 18/03/2012 11:49 pm
