JayL's Garage Shop
17 Users
Re: JayL's Garage Shop
Ambata mo pa pala sir jay:)
Posted : 30/06/2013 3:15 pm
I have a tool that i used to remove oil filter no matter what size it is pwede..pwedeng i replaced lahat ng oil filter wrenches mo na yan,
Fan belt lang gamit ko..one size fits all:p
Seriously..mahigpit ka bang mag lagay ng oil filter?
Ako kasi hand tight lang hindi naman ng lleak.
Posted : 30/06/2013 3:29 pm
Bro Bugel ... I only hand tighten oil filters. I find it better to use a piece of sandpaper when doing this. The sand paper just helps me grab the filter better instead of just using my bare hands.
I do have other filter removal tools but I favor those socket type ones since I already have the kit However I would nt suggest these for DIY use only. Other filter wrenches design would work just fine for occasional use albeit at a cheaper cost.
Posted : 30/06/2013 3:37 pm
These universal ones work too but not as good as the ones shown above ...
Posted : 30/06/2013 5:17 pm
Back to building more metal wall shelves for the woodshop ....
Rough cutting 20 feet stocks to more manageable lenght
Temporary stop block setup in the absence of a proper chop saw stand for now
Cutting 1 x 1 square tubes to fab the brackets ...
these need to be welded ....
Posted : 30/06/2013 5:24 pm
My choice in Tape Measures ......... TAJIMA
My favorite is the US Model. Both tape sides are in inches.
Posted : 30/06/2013 5:25 pm
These are older pictures. I now have a chop saw stand so doing these cutting is a lot easier.
I found a few hours to weld my shelf brackets ....
welded and grind ed ....
I need to plug the holes ....
Cut a length of 1 x 1 square tube w/ a hack saw. When choosing a hack saw it is important that the design can tighten the blade to the correct high tension. I found this yellow Starrett ( Made in Mexico ) to be a good saw. Just turn the lever in the upper handle to tension the blade. Available at Yale Hardware in CM Recto.
http://www.amazon.com/Starrett-K145-12-Inch-Tension-Hacksaw/dp/B000EOLH18/ref=cm_cr_pr_product_top
Posted : 30/06/2013 5:28 pm
If you're into metal working then a 5 or 6 inch stationary mounted vise will be very useful ..
Metal to plug the square tube holes cut to size
welding time ....
now i just need to grind and flap disc sand the edges ... and brackets are done.
Posted : 30/06/2013 5:29 pm
Brackets grinding finished ....
The easiest grinders to clean after use ... Bosch, Flex and Makita ... hardest to clean new model Metabo (dirt magnet ).
Posted : 30/06/2013 5:30 pm
Lots of 3/16" angle bar flush cutting in the shop today ...
will need a deeper cut slicer disc ... 5" is good enough
Gerald
Unfinished work yesterday continued today ...
Sure na ko me isang member dyan ngi ngiti ngiti pag binabasa itong post na ito. :wave:
Arguably two of the best 5" Rat Tail grinders in the non variable speed category are the Bosch 1821 and the Flex L3410G.
I prefer the Flex for cutting because it weigh a bit less than the Bosch.
Posted : 30/06/2013 5:32 pm
On the contrary the added weight of the Bosch makes it an excellent choice for fast grinding.
Together the above two grinders make a formidable cutting and grinding duo in the 5" class.
Grind cleanups best handled by a Bosch variable speed 4" grinder and SIA 80 grit flap discs.
Testing some new consumables
will be good for rust cleanup ... the grit I got is Medium.
Posted : 30/06/2013 5:33 pm
Great for flat surfaces ...
Page 10 / 28
