JayL's Garage Shop
17 Users
Re: JayL's Garage Shop
assembled
Swak naman
I need to build the other one and install drawer handles. These simple drawers would help keep more clutter in the shop at bay. A clean organized shop would always make a difference in the way we work ... one way or another, towards better projects that bring out the craftsmen in us just waiting for awakening.
Posted : 30/06/2013 6:12 pm
Newbie woodworkers ... get your Kreg Pocket Hole Jigs ... it is a worthwhile investment. R3 Jr or the K4 Master ... both will do the same job albeit just more perks from the more expensive kits.
I found some handles to use ...
Posted : 30/06/2013 6:13 pm
Handles install ....
Posted : 30/06/2013 6:14 pm
I'm going to edge band the TS stand ....
so I can try this Thin Rip Jig
Played with wood tapping ... I think I chose the wrong tap. Metric taps have fine threads. Next time I would choose Standard Coarse thread taps for wood.
Due to the sloppy threads I ended up mounting the nuts
Posted : 30/06/2013 6:15 pm
I just wanted to strengthen the clamp's mounting on the wood. When I get my Argon I'm going to replace this jig with an aluminum bar and weld a T-Track on top of it.
Posted : 30/06/2013 6:16 pm
I want to practice how to join wood in preparation for a future workbench build. Got these reclaimed 2 x 2 which I plan to make into a coffee table top 21 3/4" x 21 3/4".
I'll prepare the sides to be joined using the RT.
I have this flush trim bit and it's long enough for the task.
Posted : 30/06/2013 6:19 pm
I shim the out feed fence ... 1/16"
I'm not that very happy with the result
Excellent glue ready cuts but the problem is in the wood dimension ... the bit cuts shallower in the end portion due to a mis aligned fence.
Posted : 30/06/2013 6:20 pm
The MDF backer boards are warped a bit .... probably due to the RT being stored for quite sometime. I should have loosened the fence tightening screws during the long time the tool was not used.
It's good it was not the aluminum fence that had a problem. I just need to make new backer boards ... 1/2" MDF to replace the OEM ones.
Anybody have some scrap phenolic board for sale or trade .... 27" x 4.5" or a bit more?
The TS loaded with a Freud Industrial Rip blade will do for now ... till I get the RT sorted out. Maybe even better to first tune up all these hibernating wood power tools even before starting any project.
Started to tune up the woodworking tools
The RT first ... new fence. Having second thoughts if I'm going to coat these with sanding sealer or leave as is.
I'm now happy with the tolerance
This will be good enough to joint shorter stocks
Posted : 30/06/2013 6:21 pm
My favorite 1/4" plywood cutting tool. I keep buying new batteries for this basic function jigsaw because of only one distinctive advantage. Weight ... it is a very light jigsaw and perfect for thin materials.
Purchased a long time ago back in the days when Black & Decker was still a force to reckon with.
Posted : 30/06/2013 6:22 pm
more drawers ..... quick and easy builds
to be installed here ....
for power tools , chargers and what nots
Posted : 30/06/2013 6:23 pm
These kind of tools are seldom used but when you need it you need it.
Right angle drill
Stubby screw driver .... a very old purchase .. SK ratcheting type
nabitin pa ng isa ... Japan Surplus lang kasi
need to sort these storage bins out and throw junk .... then fill with more useful hardware
I got this shelves layer freed because of the wip .... LOL
Posted : 30/06/2013 6:24 pm
Page 14 / 28
