JayL's Garage Shop
17 Users
Re: JayL's Garage Shop
Bro Rosy's suggestion ... angle grinder cutting using a guide ...
looks fast and ok so I'm switching to a more powerful grinder
Posted : 30/06/2013 6:35 pm
I chose the Flex rat tail .... lightweight and with a dead man's trigger for added safety ... more than enough power for me to make a single run cut instead of multiple passes if I wanted to
LOL ... all the longer pieces sliced now ... cheaper than using a Steel Demon blade which I will reserve for more important cuts where precision is required.
I have two frames now ....
Power sanding ... using Bosch 5" angle grinder + PFerd flap disc
unlike dimensioned wood, stock metals are difficult to align even using precision squares due to inherent uneveness
for metal working using the best alignment tool we have is the better option ... the human eye
just step further backwards and spot view it .... if it looks and feels good then it must be aligned LOL
Posted : 30/06/2013 6:36 pm
I don't use it now for tack assembling miter cuts because I got the welding table already.. however it is still desirable when full welding miters so these won't warp or move.
All in all still a good useful tool ....
Posted : 30/06/2013 6:37 pm
My shelf as it stands now ( inverted pala dito sa pic hehehheh )... the last one to be built for the wood shop.
It's a bit cramped working in the garage specially if a car is parked inside and I'm doing an 80 inches long WIP. However the mig cart and the newly built chop saw stand allows me to blend easily into the available working space. I might need a slim 3 or 4 layers working push cart soon. Most of the tools should at least be in one movable carrier so I can further reduce the moves necessary while working on wips. First and foremost is thinking where I had placed down a tool. Thinking like this is a waste of time and energy thus should be converted into a reflex action.
Posted : 30/06/2013 6:38 pm
Natapos din ang frame ....
painting naman ... hindi ko na i Bronco ito ... mahirap linisin ang residue .... punas thinner and diretso primer LOL
At times I'm still amazed how fast and easy it is to paint a Wip like the one below using 3m PPS.
It's all in the ability to shoot the gun in all positions instead of repositioning the Wip itself. . I have a 600 ml cup but wished I have the smaller one too.
Posted : 30/06/2013 6:39 pm
Installing larger stuff alone is harder but doable.
A good tool to drill concrete ... piece of cake and without effort on 12mm holes. You want exactly placed holes then drill a pilot hole on the concrete so the bigger bit won't walk .
One expansion bolt for anchor and everything follows ... but the shelf is still heavy to lift alone.
Future loot storage .... LOL.
I plan to raise the dust collector above ... hope gravity won't fight the suction power that much.
One can't have too many clamps but first must have more clamp hangers
Posted : 30/06/2013 6:40 pm
I purchased these 5 years ago and had hoped never to use the tools. Well not the case now.
Broken screw extractors ...
I permanently wired 4 pcs 110V outlets in the wood shop. I hope this will clear cable clutter a bit more.
Panasonic Outlets and 12 Gauge stranded wires.
One here for the US model chargers ...
I will need a 3 or 5K watts transformer to replace this Stac Stabilizer. I have to transfer this to the garage for use on 5" rat tail grinders.
The Bosch 4100 has a good extra blade storage ... for faster blade changing.
The RIP blade .... everything was well thought out .. even the length of the wrench so it won't bind or touch the blade teeth
This year I will hopefully brave it out and paint the shop .... LOL
Posted : 30/06/2013 6:41 pm
Most of the previous posts were old photos .... will update again with new ones when available.
Thanks for viewing my thread.
Posted : 30/06/2013 6:45 pm
Ang ganda ng shop mo sir jayL! Nakakatulo ng laway ang mga tools..
Ito na siguro ang definition ng "one stop shop":D
Sir jay would you mind taking some pics of your drill press table..
Gusto ko sanang gayahin..kung kaya ko:p
Kung ano ang kailangang material
Power tools na gagamitin..
Madali lang bang gawin?
TIA!
Posted : 30/06/2013 8:10 pm
TIA!
Bro eto nag halungkat ako ng pictures.
Posted : 30/06/2013 9:03 pm
Posted : 30/06/2013 9:06 pm
Page 16 / 28
