JayL's Garage Shop
17 Users
Re: JayL's Garage Shop
Sige punta kayo dito. 😉
Posted : 23/08/2013 11:42 am
Jack Stands readily available in Binondo area and not that expensive.
Flood Water wrecks Havoc on metal stocks including junk LOL
Posted : 24/08/2013 11:13 am
Bro, that's typical of black iron tubings and other ms stocks, easily rusts when it gets in contact with water. Haven't you noticed, newly delivered square or rectangular tubings or even BI pipes are always wiped with used oil to prevent stock rustings. 🙁
Posted : 24/08/2013 12:49 pm
Di ba sir jay may metal rack ka?
Posted : 24/08/2013 1:43 pm
@ Bro Rosy ... yun loob ng square tubes napasok ng tubig and sinilip ko puro kalawang na rin.
@ Bro Bugel ... full length mga metal stocks nasa baba and hindi kasya sa mga racks.
Posted : 24/08/2013 4:58 pm
I'm planning to upgrade my Spray Painting capabilities a bit.
This is my current compressed air setup and delivery system.
I get my spray painting air from the Blue Campbell Hausfeld water filter separator. Both the black Parker Filter Regulator and the Campbell Hausfeld water separator are rated at 5 Micron capability.
I want to add these in the air loop.
For spray painting I chose the Swan 3/8" hose with 1/4" NPT Male ends. The reason why I wanted to use this PVC hose is because it is nimble and lightweight. Rubber hoses are too heavy for my liking when it comes to spray painting.
At the business end of the hose I will install a Dynabrade Dynaswivel connector. This will allow me to position my spray gun 360 degrees x and y axis.
Posted : 30/08/2013 6:13 pm
I also want to insert this new Filter Regulator in the air lines to supply drier spray painting air.
This is what the model number says :
Series - 2000
Port Size - 3/8 inch
Filter Element - 0.3 Micron Coalescing
Pressure Range - 0 to 140 psi w/ flush mount gauge
Bowl Option - Relieving / Metal w/ sight glass
Control Drain Option - Automatic
Coalescing 0.3 Micron Filter
Now if only I get chance to scout Binondo and buy the pipes, valves and fittings that I need ... preferably Milton or Acme only for quick disconnects.
Posted : 31/08/2013 12:20 am
These days 99% of the time I only purchase Ingersoll Rand and Chicago Pneumatic air tools. Got tired of the generic ones that uses a lot of air but provides less work output. Compressed air cost money and if an air tool brand will not maximize it then I'm not buying it.
For my personal use I have mostly Chicago Pneumatic.
Posted : 01/09/2013 10:39 pm
Norseman Drill bits sharpening ....
Posted : 04/10/2013 7:36 pm
Setup
Sharpen 135 Degrees
Split Point
Testing
Posted : 04/10/2013 7:37 pm
(@narako)
wow!!! dream garage/workshop/tambayan!;)
indeed...para kang batang nasa loob ng toykingdom sa garage ni sir jayL.
hayyy....kailan kaya ako magkakaroon ng ganitong workshop.
Posted : 05/10/2013 10:02 pm
Welcome to my Garage Shop thread bro and thanks for visiting.
Posted : 06/10/2013 2:14 am
(@narako)
sir JayL...first page up to the last page inisa isa kong tingnan kahit sobrang bagal ng net namin.:(:mad:
pati mga ads mo sa sulit tinitingnan ko lahat. 😉 kahit wala akong pambili.:D
Posted : 11/10/2013 10:34 am
@Jay, magpaskil ka ng kalatura sa gate mo:
HASA! HASA!
HASA ng drill bit P10 per piece 😀
ang sarap magbutas ng mga bakal kapag may Drill Doctor, kahit pumurol walang problema.
Posted : 18/10/2013 8:41 am
Page 20 / 28
