metal working table
8 Users
Re: metal working table
@ryobi,
here are photos from welding world site..id like to have a welding table fashioned to something like this.
yesterday i switched on my welder a bit just to try the welding helmet with ADF..results were promising and later today because of utter excitement i bought some angle bars (1 1/2 x 3/16, 10mm square bars and a piece of 1 x 3/16 flat bar):
Price: angle bar (354p/pc), square bar (250p/pc), flat bar (100p/pc)
ready to ramble tomorrow.will take pics to post.
wish me luck!
This is a very good idea Doc perfect for my table thanks doc....:D
and good luck for your metal project go go go Doc........
Posted : 08/05/2011 9:44 am
not much work for today very busy pa rin sa company
just update only hehehe
here something to add......additional 2 x 2 square tube and 2 x 3 square tube
sorry for out of focus hehehe
later apply rust converter and paint epoxy primer and paint black enamel before i place a GI sheet #18
Great metal working table there ryobi, your table top will be well supported with that kind of construction support, just hope you get a much thicker table top, maybe a 1/4" or 3/8" thick metal plates. 😉 :p
I'm currently making one too.
Posted : 08/05/2011 3:45 pm
@ryobi,
ay buti nalang pala sumakto post ko for your table..show the wips ha..i want to know how youre going to make the slot for the vise sub base.
anu ba da best brand ng metal primer? yung paint application lang po..ala ako spray kasi..
yung angle bar pala rough din ang surface..kaya pangit pagka paint ko nung AC support..malapot at old stock na kasi yung primer ko..parang gummy bear/anti rust paint consistency kaya mas lalo naging rough yung finish..inispray ko pa naman using acrlylic spray paint..inubos ko yung spray paint! nanggigil ba!
Posted : 08/05/2011 6:52 pm
@rosy
thanks I prepare GI sheet #18 for the top of my table Hmmmm i think thats a good idea for 1/4 thick metal plates
@ryobi,
@ doc
best brand ng metal primer ay Galva cote the one that i use today pwede rin brush ang gamitin damihan mo lang acrylic lacquer
Posted : 09/05/2011 12:18 am
what a rainy day anyway here is my wip this morning
snip GI sheet for the top of the table and overlap 2 inc.both side
and also at lower part
clamp using 2x2 square tube and c clamp
Posted : 09/05/2011 12:24 am
Posted : 09/05/2011 12:25 am
using ball hammer
Posted : 09/05/2011 12:28 am
and then at back of bend sheet for hammering to make it straight
macho!!!!
here is left and right
Posted : 09/05/2011 12:33 am
and then mark the exact square hole for the slot i will make both end of my table
for tomorrow cutting
to be continue.........
Posted : 09/05/2011 12:42 am
ganito, ayaw mo? 😮
@ doc
Posted : 09/05/2011 9:38 am
ganito, ayaw mo? 😮
hahaha eto na lang tamad me ngayon magtimpla
Posted : 09/05/2011 11:26 am
woke up late again masarap matulog malamig hehehe
well paint red oxide metal primer
and then square hole both 2 end of the table
that's it may work pa ako hehehe to be continue........
Posted : 09/05/2011 11:33 am
Bro Ryobi. I tried your miter bending technique on 1" x 1" x 3/16 angle bars. When I bend napuputol. Am I missing something on the bending technique?
Posted : 09/05/2011 2:03 pm
@ JayL,
If you don't mind me answering your question kay ryobi, maybe my answer will be close to what he will say.
I think bending the square tubing will not give a hassle since its thickness is only 1.0mm or 1.5mm so its not really that thick, like a linzo or a 15, i6 or18 gauge mild steel plate, these can easily be bent with a metal bender and it will not snap off or mapuputol compared to what you did with the 1" x 1" x 3/16" thick angle bar. Sir Jay, 3/16" is 3/16" , much thicker than the aquare tubing.
Maybe while bending the angle bar you should have used your oxy-acetylene torch and slightly heated up the part hanggang mag baga, that portion you were supposed to bend just to soften the thick mild steel.
Also hardware owners here in our place have this sentiments and are questioning also steel suppliers how come nowadays ang yari na ng bakal ay malutong na specially sa mga rebars, madaling maputol and customers are complaining too.
Posted : 09/05/2011 3:25 pm
@ JayL,
Thanks Sir Rosy. You just confirmed my thoughts. Malutong yung bakal. I might try adding heat next time.
Posted : 09/05/2011 4:34 pm
Page 2 / 4
