@ryobi,
me too i prefer the branded and reliable one, baka pag meron ka ng mig e hindi ka na tumigil kaka welding hehehe
Posted : 09/01/2011 11:59 am
Ossie i got this from janmike @ sulit for info lang...
*What is gas and gasless wire? => Gas wires require gases like co2, argon or mix for proper welding. Without it welding is still possible but produces very weak or useless welds called porosity. Gasless wires on the other hand does not need gas to properly weld. It is a general purpose indoor and outdoor welding wire as opposed to gas wire which is generally indoor use.
*What is the difference with gas and gasless wire in terms of welds? => Gas wire with proper shielding gas have cleaner welds, perfect for very thin sheets and panels, stronger joins and much cheaper. Gasless are flexible wires that can be used on-site, perfect for thicker metals, rusty and contaminated metals.
*How do i know the right wire for my mig? => Generally a flux core wire is compatible to all kinds of mig AC or DC but it is highly recommended for DC type migs at DC Electrode Negative (DCEN) for optimum performance. However the size depends your migs rated amperage. A 90amp AC mig can only handle up to 0.8mm(0.030") wire ideally @ full power while a DC 90a mig can handle up to 0.9mm(0.035") @ half power. Remember to use the proper nozzle tip size. Gas wires require DC migs with proper shielding gas and as an example a 90amp DC mig in DC Electrode Positive (DCEP) is a minimum requirement for use with a 0.8mm(0.030") mild steel gas wire to obtain a satisfactory weld.
*Which wire size can i use for my mig? => AC migs can only use flux core wire. With a 90amp mig it can use up to 0.9mm wire @100amp up to 1.0mm , @120amp up to 1.2mm, @150a up to 1.6mm. DC migs can handle both GAS and GASLESS wire with 90a upto 1.0mm - 110a upto 1.2 - 135a upto 1.6mm.
Posted : 09/01/2011 12:00 pm
bro pupunta ka ba 1st EB natin jan.15 sat. para makita mo naman mga new toys hehehe dalhin mo na rin yang bago mong gawa steel bender hehehe at demo sa amin:D
Posted : 09/01/2011 12:06 pm
thanks for the info Ryobi.
haha mabigat bigat yung bender e at mahaba haba ang handle, bike lang ang dala ko hehe planning to go but cant promise pa 😀 umorder ka ba ng MIG? hahahaha
Posted : 09/01/2011 12:11 pm
auto darkening helmet muna may welding machine pa naman me kailangan ko na kasi gagawa ako ng overhead tank 😉
Posted : 09/01/2011 12:15 pm
so kasama sa box yung auto darkening helmet mo? pls post your wips here 🙂
Posted : 09/01/2011 12:20 pm
hindi ksama sa box yun sa fineline me bibili maybe thursday makuha ko na ... Pwede ko rin dalhin sa 1st EB`s for demo 😉 hehehe pupunta ka ba?:rolleyes:
Posted : 09/01/2011 12:27 pm
OK yan bro dalhin mo sa EB Auto Darkening Helmet mo para makita namin. Ossie go go go na. Yan din talaga kailangan natin. Helmet muna.
Ako di ko pa din makita mabuti weld puddle sa helmet ko. Nag switch na nga ako sa #9 na lens instead na #10. Mas lighter ng konti ang shade.
Etong mga style na ito mukhang maganda din. Mid range - 3 sensors. Kahit Chinese compatible basta pasok sa ganitong specs ( masusunog sunog din lang naman ng spatter ang helmet). Miller Korean made lens gamit nila pero mostly yung ibang brands China. Snap On nga China na mga lens nila.
http://www.weldfabulous.com/Welding-Helmets/Miller-Auto-Darkening/Titanium/Miller-245800-Titanium-Series-p8507236.html
or
http://www.weldfabulous.com/Welding-Helmets/Miller-Auto-Darkening/Performance-Series/Miller-232036-HelmetPerformance-p4543602.html
Snap On
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=88919&group_ID=1751&store=snapon-store&dir=catalog
( Pansinin mo sa specs ang country of origin )
Mahigit 9,000 views na welding related thread. Mukhang madami interested sa welding. Nag a antay lang siguro ng mga katulad ninyo na mga young ones pa at masipag talaga mag WIPs. Me potential lumaki members ng metal enthusiasts.
Posted : 09/01/2011 12:47 pm
yes i`ll bring it on saturday to see it .... with liempo pang kasama hehehe:D
Posted : 09/01/2011 1:21 pm
dalhin mo na din yung welder machine mo para ma demo talaga yung helmet 😀
etong helmet sa Northertool.com http://www.northerntool.com/shop/tools/product_200311850_200311850
USD47.99 lang
This Northern Industrial welding helmet features a classic black helmet design with red flame graphics on the sides, top and front. The Auto-Darkening lens has a sensitivity adjustable variable shade. Solar powered so you never have to be concerned about battery life.
Key Specs
Auto Darkening Yes
View Area W x H (in.) 3 7/8 x 1 3/4
Switch time (sec.) 1/25,000
Adjustable Sensitivity Yes
Variable Shades 9 - 13
Adjustable Fit Yes
Power Supply Solar
Base Type Auto Darkening
Low Battery Indicator No
Battery Included [COLOR="Red"]Yes, but cannot be replaced (NGEK!!!)
Manufacturer Warranty 12 months parts / 12 months labor
Ship Weight 2.0 lbs
Item# 1649902
Posted : 09/01/2011 6:32 pm
pwede mag welding na lang tyo dun libre kuryente hehehe
Posted : 09/01/2011 6:37 pm
9,000+++ views na nga, isipin mo napansin mo yun? hindi kaya tayo lang yung paulit ulit na tumitingin sa thread natin hahaha
ako naman gusto ko mag switch sa more dark na lense kasi medyo nalilinawan pa mata ko hehe
pag hindi libre kuryente kay Timber, dun tayo sa shop ni Jay mag eb at mag welding hahahaha joke lang po ha... papayag naman si bossing kasi saglit lang naman at wag lang weweldingin yung pinto ng shop at gate ng compound hehe
Posted : 09/01/2011 6:39 pm
eto pa o:
SALE @ 54.99
Harbor Freight
http://www.harborfreight.com/blue-flame-design-auto-darkening-welding-helmet-91214.html
Description of Chicago Electric Welding Systems 91214
This welder’s helmet features a superior auto-darkening lens that makes this your best bet for arc, MIG or TIG welding. Plus, that lens measures a large 3-7/8" x 1-5/8" wide to give you a full view of your welding work area. Ratcheting headband and padded interior provide a comfortable fit, and the cool design makes it an auto-darkening welding helmet you’ll be proud to wear. Automatic power on/off with adjustable delay time.
Darkens in 1/25,000 second (clear #4 to dark state)
Variable shade control - shades #9 to #13
High/low light-sensitivity adjustment
UV/IR protection
Meets ANSI Z87.1-1989 standards
Posted : 09/01/2011 6:44 pm
tsk tsk ang gaganda ng helmet deeg pa helmet ng motorbike
Posted : 09/01/2011 6:47 pm
Page 17 / 79
