Where were you able to get your right angle clamp?
Posted : 10/03/2010 9:09 pm
bbn
 bbn
(@bbn)
Those are nice clamps JayL. So as Bee said, where and how much did they cost?
Bosch I was told is the only maker that has a variable speed grinder which would be great when you want to go slow and easy.
Posted : 10/03/2010 9:30 pm
Panda Construction - 2,800 pesos.
Yes the variable speed is a great feature plus it maintains constant speed at a given setting even under load.
Posted : 11/03/2010 7:42 am
American Tool Companies VG Quick Grip welding clamp - length = 6"
Posted : 11/03/2010 11:21 pm
Had some chance to practice on basic metal cutting. 1" x 1" angle bar 4mm thick.
Abrasive saw cutting is not so true and accurate plus a lot of burrs on the cuts.
Burrs cleanup using angle grinder. I'm beginning to like the light weight and variable speed of the Bosch.
Posted : 12/03/2010 5:56 pm
Dry fits.
I'll try to weld these bars later and see how heat affects metal and the corresponding warping issues.
Posted : 12/03/2010 5:58 pm
panay na panay ang tool shopping mo ngayon ah... nice bro...
Posted : 13/03/2010 1:14 am
Just like you I try to stack up on tools to make jobs easier.
Would you happen to know if Bosch has a dry cut metal saw available locally?
Posted : 13/03/2010 11:01 am
not sure about the item bro. is it the same as a chopsaw?
Posted : 13/03/2010 11:39 am
Yes the same body style but runs at a lower rpm and is loaded with a carbide tipped metal cutting blade instead of an abrasive wheel.
I called Makita and they have one for around 24K. Ouch
This saw is still manufactured in Japan.
http://www.amazon.com/exec/obidos/tg/detail/-/B00004YOLV/ref=ord_cart_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
Posted : 13/03/2010 7:01 pm
Started joining my project today.
My make shift table. I'll hopefully build a proper welding table later when I feel more comfortable with my skill level.
I'm welding using 1/8" 7024 drag electrodes at 160A ( AC Stick Welding )
Tack Welds
Full Welds
Posted : 13/03/2010 7:16 pm
Cleanup
Unfinished work. I still need to buy 2mm thick mesh screen for the top.
Posted : 13/03/2010 7:19 pm
I found some soap stones today. Very good for marking metal. 5 pesos each.
Posted : 15/03/2010 11:29 pm
I also found out today that metal wire mesh ( 4mm) are only sold by 4' x 20' & 6' x 20' size. Much like plywood.
I just have to use scrap sheet metal for the top as I don't want to buy a whole mesh.
( 5/64" thick / 14 gauge)
Posted : 15/03/2010 11:34 pm
I would have preferred a circular saw to cut this to size but I don't have a metal cutting blade yet. Planning to get one later.
http://www.amazon.com/exec/obidos/tg/detail/-/B00008WQ3B/ref=ord_cart_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
I had to do with what I have now. A jig saw with a metal blade.
Slow but I finally cut the sheet to size.
Posted : 15/03/2010 11:39 pm
Page 2 / 79
