@timb,
yes, it was 5 years ago. its a concrete mouldings. 🙂
i also created a thread to post the pictures for all of you guys to see 🙂
http://www.pinoyhandyman.com/showthread.php?p=14356#post14356
sample:
thanks
matanong ko nga lang, Ossie, di ba dati masonry tinitira mo? concrete forming nga ba yun?
Posted : 19/01/2011 2:29 pm
Eto ok pang Tik Tik ...... the spring makes it more comfortable. I have one and it works well.
http://www.amazon.com/US-Forge-Welding-Economy-Chipping/dp/B000UPD8AO/ref=pd_cp_hi_2
or
Cross Head
http://www.amazon.com/Hobart-770067-Chisel-Chipping-Hammer/dp/B002ACOXO0/ref=sr_1_1?ie=UTF8&s=industrial&qid=1295419063&sr=8-1
Posted : 19/01/2011 2:42 pm
kainis nga kasi wala yata dito nyan locally e 🙁 wala din sa napagtanungan ko sa binondo
balak ko gawing chisel tip at pointed tip yung MAYHEW ko 😀
or
Cross Head
Posted : 19/01/2011 6:09 pm
Anong Mayhew yan. Patingin.
Check mo din mga jigs dito.
http://www.youtube.com/watch?v=pZJc8a-6nx0
Bro you got PM.
Posted : 19/01/2011 6:24 pm
my bosch angle grinder suddenly shutdown while while grooving the wood este the metal bar this afternoon.
i switched it on and off, on and off again. checked the plug for connection and its all ok.
waahhh thinking of another gastos na naman to buy and replaced my 10 years old grinder or to have it repair while opening the cover.
i removed the carbon brush and found this, the spring touches the rotor and shutdown the power. i have carbon brush bought i think 3-5 months ago coz im going to replace it na hehe hayan napalitan na hehe the grinder is now ok and working good, haayy salamat walang gagastusin hehe
its good the rotor did not damaged. i measured the used carbon brush and its only 8mm now. its better to have it replaced before it reaches 8 mm, 10-12 mm perhaps? 😀
Posted : 19/01/2011 6:32 pm
my bosch angle grinder suddenly shutdown while grooving the wood este the metal bar this afternoon.
waahhh thinking of another gastos na naman to buy and replaced my 10 years old grinder or to have it repair - while opening the cover.
Posted : 19/01/2011 6:33 pm
@jay, eto hehehe
Bro you got PM.
Posted : 19/01/2011 6:52 pm
@jay, eto o hehe
ngeks kinalawang na pala yung isa 😀
Posted : 19/01/2011 6:54 pm
@jay, eto o hehe
Bro you got PM.
Posted : 19/01/2011 6:55 pm
Wag mo na galawin yang mga punch. Sayang. Maganda pantanggal ng pins yan.
Ganito na lang gawin mo.
Posted : 19/01/2011 6:57 pm
planning lang naman kasi naghihinayang ako kasi isang set sya... mayroon akong 2 piraso na maliit nyan, ginawa kong pointed, sarap pang tanda sa metal na bubutasin 😀
Posted : 19/01/2011 7:02 pm
Oo ako meron din pang tanda ng metal. Kailangan talaga. Kakainis ngayon lang nabakante garahe. D ko tuloy naputol yung mga flat bar. Gumabi na. Bukas na lang.
Mura ng bender sa Harbor Freight. Me kasamang 7 dies. Dito sa atin wala ng mga ito o sobra mahal.
http://www.harborfreight.com/compact-bender-38470.html
20% discount pa yan pag me coupon ka.
Mas mura pala yun sa yo.... mga 400 pesos lang gastos hehheheh kasama na kuryente. 🙂 wala lang dies.
Posted : 19/01/2011 7:14 pm
ok lang yan at ngayon lang nabakante garahe mo, meaning pinapag pahinga ka mabuti hehe
ang die set na kailangan mo is yung sa pipe, yung die set na kasama kasi nyan e pang normal bending lang sa metal bar na depende sa laki ng angle.
yun nga lang kasi hindi available sa atin kaya DIY na lang hahaha
Posted : 19/01/2011 7:34 pm
dito ka na lang:
12 Ton Hydraulic Pipe Bender = USD99.99
Constructed of a heavy duty steel frame, the 12 ton hydraulic pipe bender can handle round or square solid rods up to 2" thick. Bending bars can easily be adjusted to distances of 8-1/2", 11-1/4", 12", 16-3/4", 19-1/2" and 22-1/4". Six precision cast dies are included.
Bends 1/2" to 2" thick round or square solid rods
Bending bars can be adjusted from 8-1/2" to 22-1/4"
Jack capacities: 13-1/4" minimum, 22-3/4" maximum
9-1/2" stroke
Includes 6 precision cast dies
Die sizes: 1/2", 3/4", 1", 1-1/4", 1-1/2" and 2"
Handle: 17-5/8"
Overall size: 24" wide, 6-1/2" deep and 21-1/2" high
Shipping Weight: 83.00 lbs.
http://www.harborfreight.com/12-ton-hydraulic-pipe-bender-32888.html
Posted : 19/01/2011 7:49 pm
Ang daling gawin niyan. Problema lang yung mga dies.
Parang maraming restrictions din ang design na yan.
Mukhang kasya na yun flat bars. 4 pcs x 12 in then me sobra pang konti pang sapi sapi.
Pareho ba tayo ng mga dowels. Di ba parang malambot?
Posted : 19/01/2011 7:54 pm
Page 28 / 79
