i made 86 cuts at 1 1/2 inc. distance
and consume 2 and 1/4 cutting disk at 4 inc. diameter
result nag bent na hehehe tomorrow full weld na ito eto medyo makapal na ung bakal ......may pasok pa ako mamaya pang gabi kasi ako ngayon
Posted : 07/02/2011 6:35 pm
hanep, bagsik mo! isa kang makamandag na Zombies, pero hindi ka makakalabas sa Plants mo hehe ang daming korte nun ha? at maraming bends hehe
go go Ryobi!!! dont forget to post pictures, tignan namin yung step by step bending mo ng angle bar hehehe
jonathan / ossie / guys
here is first built i made year 2002 bago pa lang magkaroon ng plats and zombie meron na ako yan ako ung zombie na nasa bahay hehehe
main gate
Posted : 07/02/2011 6:39 pm
ang bangis mo Ryobi, isa kang makamandag na Zombies, ang daming korte nun at ang daming bend nung mga Plants mo hehe
wow! aabangan namin yang builds mo.
about dun sa grinder mo, ilagay mo yung disc guard for safety reason, you cant tell baka magkaproblema ang disc mo - wag naman sana, at para din ma protektahan ka sa mga spark.
work safe bro...
isa kang GRANDMASTER!!!
Posted : 07/02/2011 6:50 pm
mukhang ok ito gamitin after metal working 🙂
magkano naman score mo sa ganito? i think i need one, recommended ba? ayaw ko kasi magbasa ng kamay agad lalo na pag nag welding, im using wipes lang para luminis linis ang aking kamay hehe
For Oily and Greasy hands this is my choice for a Hand Cleaner. Works well and have been using the product for a long time now.
Posted : 07/02/2011 6:58 pm
work safe bro...
anong GRANDMASTER DIY lang yan ayaw lang magbayad ng labor hehehe about ung disc guard yap lalagyan ko yan kaya lng hindi ko makita kung saan ko nailagay magulo mga kagamitan ko dito sa haws ko hehehe
Posted : 07/02/2011 7:22 pm
naku! asan na nga ba din yung disc guard ko????
Posted : 07/02/2011 7:45 pm
clayfigur
(@clayfigur)
I just checked my 6013 rods. I have 4mm and 4.7mm.
Have you tried using the 4mm for thinner gauge metal?
Yes, made some nasty holes with it..
For thin metals, I use 3.2mm 6013 rods by Nihonweld they cost P140 per kilo.. Kinda pricey but worth it..
I also tried the 3.2mm 6011 by IT weld.. cost P160 per kilo, its sparks well, even at #1 setting for Powercraft welder...
Posted : 07/02/2011 7:52 pm
@ Ossie
Yan na nga pang pahid pahid muna. Iwas pasma. Isa pa madaling magsabon at linis ng kamay later. 210 pesos sa Ace. Pam pa landi ng DIY yan mga yan. Hehehehehe
Ang bangis ng mga WIPS ni Sir Ryobi. Bro ikaw ang counterpart ni Chisel pagdating sa Bakal.
Posted : 07/02/2011 9:02 pm
clayfigur
(@clayfigur)
i remember you posted your different brand and different amperage rating of your welders, why not use the heavy duty one so no need for modification to your small welder?
Sometimes.. I use the small welders especially the portable ones, if the project is immovable, or out of the garage... The heavy duty welder, its good and has longer duty cycle, but kinda heavy...
That's the reason why I need to modify the light ones...
Posted : 07/02/2011 9:44 pm
hey Clay,
from where are you? it seems that your rods are bit pricey, rod per kilo in bacoor is Php100 Nihonweld
Posted : 07/02/2011 9:48 pm
bawasan mo kasi gamit mo, sobrang dami na kasi e, tulungan kita bawasan yan 😀
hala, magtatampo na angle grinder mo, mukhang hindi mo na saw sya nagagamit hehe
im my previous company na pinagtratrabahuan ko, im using hand renovator - drakkar scented 😀 ang bango bango hehe
Posted : 07/02/2011 9:54 pm
clayfigur
(@clayfigur)
Here's the transformer of jiali 200A..
Here's the fan I bought form Raon
I measured the temperature with an industrial mercury thermometer, it reads around 40 degrees without load, when I add the fan, it reads around 34-36 degrees. (Nawala na sinat nung trasformer..)
I'll try tomorrow to test the temperature while welding in heavy settings...
Posted : 07/02/2011 9:58 pm
@clay,
pls try this the link - tutorial in posting pictures http://www.pinoyhandyman.com/showthread.php?t=1207
Posted : 07/02/2011 10:05 pm
clayfigur
(@clayfigur)
@clay,
Noted sir... I edited it already..
hey Clay,
It is, because I just buy them from the local hardware.. But, some times I buy in Binondo, Its cheaper by almost 30-50 pesos...
Anyway, Im using Nihonweld special 3.2mm 6013 and 6011
About ITweld, Im using 3.0mm and 3.2mm I use it for thin metals, sometimes even on sheet metals and welded wires..
Most of my projects are kinda thin and lightweight..
I only use 4mm rods when cutting and on thicker metals.. It cost around 50 pesos/kg here.
anyway, Im near makati...
Posted : 07/02/2011 10:06 pm
thanks.
if you have time, pls try to capture and post some pics of your projects 🙂 baka pwede namin gayahin hehe
Posted : 07/02/2011 10:15 pm
Page 50 / 79
