first built i made year 2002 bago pa lang magkaroon ng plants and zombie meron na ako yan ako ung zombie na nasa bahay hehehe
2002 pa yan eh anong year na ngayon? pabangis ka ng pabangis!!!
Posted : 07/02/2011 10:49 pm
si ryobi - mabangis at makamandag!!! hehe
nanaginip ako kanina, nasa class session daw ako ng lathe/cnc/milling machine 😮
grabe JayL ang virus mo sa metal working!!! kumakalat hahahaha
Posted : 07/02/2011 11:00 pm
Got chance to get a 15mm drill bit and an M12 x 1.25 Tap set.
So I continued with the bender handle. Tapping holes need tender care. The right hole size for the Tap to be used is imperative. There will be times when this will be a better option than welding pieces together. Good chance to practice in this build.
Needs lot of cutting fluid. Have to turn clockwise to cut , back out counterclockwise a bit then cut again.
If available blow with compressed air from time to time.
Posted : 07/02/2011 11:14 pm
Drilled and Tapped holes. Fine metric thread. Fits well.
Don't you think I need to move the handle a bit more on the middle inside ( second bar ) for stability? Will need a 22mm hole saw to do that because the handle shaft itself has a bigger diameter. 🙁
Short handle out.
Longer adjustable one in.
Posted : 07/02/2011 11:18 pm
wow! iwewelding na lang ba yan?
if you can adjust your handle going inside for about 3 or 4 inches or up to the other bar, much better for stability...
Posted : 08/02/2011 4:53 pm
ang sarap siguro gumawa ng butas hanu???lalu na kung quality hand taps! never tried yet and dont have any hand taps for that matter...me oil pa pala nilalagay! hmmmm
oi ossie ha..baka me reply ka na naman na kung ano jan???
:p
Posted : 08/02/2011 5:11 pm
[COLOR="Green"]ayos lang, maliwanag naman ang iyong mga binanggit na mga kataga e hehe 😀
:p
Posted : 08/02/2011 5:15 pm
Kaya nga hindi ko pa ma welding dahil dito. Palagay mo hindi pa siya stable? Bakal naman ito.
I will need 22mm hole saw to do the adjustment. Gastos sa tools. Kikilin ko na lang kaya pero madugo yun. From 15mm to 22mm. 🙁
Posted : 08/02/2011 5:22 pm
for that build, kailangan ba removable yung handle?
Posted : 08/02/2011 5:25 pm
kasi mapwepwersa masyado yung dulo ng handle mo 🙂
Posted : 08/02/2011 5:30 pm
Absolutely not 🙂 .... practice practice lang muna trying to build skills. Taking the chance on this instead of doing on scrap.
Hmmm I never tried a hole saw yet on metal.
http://www.amazon.com/Lenox-Tools-1221414A-Arbored-8-Inch/dp/B003JBJFBC/ref=sr_1_2?ie=UTF8&qid=1297158174&sr=8-2
How can I make a 16mm hole to be tight 22mm on a 1/2" flat bar if I don't have a hole saw?
Another option for me is to try it as it is. If the handle does not work well then I could just do a hole using oxy ace and weld it.
Posted : 08/02/2011 5:31 pm
as of today this my 3rd day of delubio har har !!!! its welding time
here is what i have done today molding using with c clamp and curve pattern a 1/4 plywood
spot weld
and then remove 1/4 plywood
Posted : 08/02/2011 6:17 pm
now full weld
weld !weld! weld! it consume 20 stick of 6013 welding rod
palakang bato weld need more practice! practice!
Posted : 08/02/2011 6:22 pm
and then 2 hrs of grinding
so done na ako sa isa need one more of this hehe needs to take lots of vitamins and a lots of energy drink like cobra!!! tibay at lakas cobra:mad: har!!! har!!
Posted : 08/02/2011 6:27 pm
@ryobi,
some advise from a newbie like me 😀
clean the metal as much as possible, dirty metal also affects your beads in some ways.
try to weld the metal in flat position,(if you can). i saw your picture that you are welding in a vertical position (is it uphill or downhill?)
try to use 2.5mm for that build @ 90 deg para hindi masyado malaki kakayurin mo sa grinding 🙂 hehehe
grabe, mas matiyaga ka pa pala sa akin hehe
go go go garndmaster Ryobi, gusto ko na makita yung ornamental designs na ilalagay mo
Posted : 08/02/2011 6:41 pm
Page 51 / 79
