@beedigo,
just called my suking hardware store this morning, i inquired about the rod for "pundidong bakal". they have EUTECTIC brand and cost Php15 per piece. no rod code number like 6013, 6011 etc, just ask them for "pundidong bakal" hth
just want to ask, do you guys have an idea what do they call the welding rod for "pundidong bakal"? 'coz I brought the plate of my drill press to a welding shop after it got cracked, and they guy said he needs a rod for that. But when I got to the hardware store, they dont know what it is. TIA
Posted : 11/02/2011 10:30 am
@john,
hey bro, you are really a busy man hehe
you can use lots of clamps and alternate welding from side to side will do the trick 🙂 i dont like to pour water in my work place, its kinda messy 😀
Posted : 11/02/2011 10:46 am
(@beedigo)
@clay,
thanks for the info, but I think the shop doesnt have the acet-oxide. I guess I have to stick with the stick:D
@ossie,
thanks for the trouble of asking your suki, I'll just try to look for other hardware stores that might be selling them.
Thanks again guys.
Posted : 11/02/2011 11:23 am
@beedigo,
no problem, glad to be of help to our PHM community 🙂
@ossie,
Thanks again guys.
Posted : 11/02/2011 11:30 am
(@beedigo)
Just an update, just got my drill press plate welded. I finally bought 1 weld stick for the pundidong bakal at one of the several hardware shops here at our place, and he's the only one selling it. And I can't complain on the price (it's 140pesos per stick!:eek:). It's a good thing the welder only needs 1 stick. Thanks again guys.
Posted : 11/02/2011 8:05 pm
@beedigo,
good to hear that your drill press' plate is now ok... and, its not good to hear that the price of the rod you used is also the same price of 1 box (5 kg) of welding rod 😮
Posted : 11/02/2011 9:55 pm
Cast iron seems to be a difficult weld. Glad the DP table is now ok.
Here are some Stick Welding Guidelines, Tips and Hints from Miller.
http://www.millerwelds.com/pdf/guidelines_smaw.pdf
http://www.millerwelds.com/resources/articles/index.php?page=articles16.html
http://www.millerwelds.com/resources/improving-your-skills/stick/
@john-jo
Welded metal movement is really a pain. None the less we're now learning how to tame it or at least contain it.
Auto Darkening Helmet is really a plus investment. It's very difficult to weld well if we don't see the weld puddle clearly. 🙂
Posted : 12/02/2011 2:23 am
Here are some Project Resources we can check for WIP ideas.
http://www.millerwelds.com/interests/projects/
Posted : 12/02/2011 2:50 am
The bender base needs to be fabricated. I decided not to full weld the handle yet and do all this in one shot.
This is an easy and cheap build but will be very useful for metal works. I hope other members will make one for their shops too.
Posted : 12/02/2011 3:06 pm
Yes!! Yes!!of course I need that too and I want to built my project.... right now I'm dealing with giant metal gate and some bending needed too....:)
Posted : 12/02/2011 5:49 pm
@ ossie here is some item that i got in binondo wow muntik ng kapusin ako sa budget hehe
Nehonweld special 6013 2.5mm 10 kilos wort P1200.00 5 kilo wort of P750.00 so I got 1200 pesos
wow ang dami nito
inside of the white box have 2 boxes equal @ 5 kilos
data setting of welding rod
Posted : 12/02/2011 5:56 pm
Wow!!! and dami nito
compare of 2 welding rod the 1rst rod 6011 @ 4.5 mm and the 2nd 6013 @ 2.5 to 2.9 mm hmmm I think because of flux which is vary the thickness of welding rod
Posted : 12/02/2011 6:01 pm
Ornaments are getting popular this item cost 50.00 pesos so i got a hundred pcs. of this
leaf left and right wort of 28.00 pesos each i buy a hundred pcs. for this...
here is other design
Posted : 12/02/2011 6:08 pm
Dyna bolt 3/8 wort of 16.00 pesos each
Dyna bolt 5/16 wort of 12.00 pesos each
and Insert nut 6mm plus allen flat head 6x45 worth of 13.00 pesos / set
Posted : 12/02/2011 6:13 pm
@ryobi,
wow! shopping to the max! thanks for posting especially the item's prices.
Posted : 12/02/2011 6:40 pm
Page 56 / 79
