wow! ayan na si doc! mag wewelding na, nice ADH ha? sa wakas nabili na din hehehe waiting for the wips...
may darating na kulay blue sa bandang June, kaya itineterno na halos lahat 😀
Posted : 20/04/2011 11:44 pm
@ossie,
magpapanggap lang muna ako bro..talagang newbie toits..now i do not know if my "daihatsu" arc welder can do welding at all..will post a pic of whole thing.
@Jay,
naku dinala mo ako sa WeldingWeb...madugo pala dun! but great site! dami kong nakita pictures to suit my needs kaya lang mega heavy yung iba...kailangan nga pala thick metal plate sa table..agh!
akala ko pwede na kahoy sa mount ng vise.lol
isip isip muna...baka ihold ko muna vise stand..il get the ordered items from timber today later and continue with the router table..in between il try to sketch the vise stand..parang mas ok yung table instead of a single post build (see nctox post).
and i saw a chop saw stand..ok din..pero mas ok mag cut ng angle bar sa ground i guess rather than lifting the whole 20' (with support on either side)...but like i said i cant squat.
thanks
Posted : 21/04/2011 4:09 am
A bench top or floor model belt sander would be an awesome tool to have when fabricating metal parts.
http://www.vansantent.com/multitool.htm
pics borrwoed from GJ
http://www.sulit.com.ph/index.php/view+classifieds/id/1527748/Torq+table+type+belt/disc+sander?referralKeywords=belt+sander
Posted : 21/04/2011 4:02 pm
It's good idea to load up a file with chalk before filling away metal. Keeps it from clogging up quickly.
Posted : 21/04/2011 7:47 pm
how can i bring back the luster of my bellota bastard file? rusty but still very much functional but it looks dirty.
tia
Posted : 21/04/2011 8:18 pm
tia
I wanted one of this for a long time now. Don't know if available locally.
http://www.amazon.com/Steelex-D2658-File-Card-Brush/dp/B000661868/ref=sr_1_4?ie=UTF8&qid=1303393219&sr=8-4
Did you try to soak it in WD40 already?
Posted : 21/04/2011 9:43 pm
clayfigur
(@clayfigur)
tia
I use a wheel wire brush in cleaning my files.. I use a emery chalk on it before cleaning with a wheel wire brush.. Hope it works well for your file..
Posted : 22/04/2011 1:27 pm
My air hose reel swivel is taking shape already.
I'm really hoping that my welding will improve a bit when I get my ADH.
No bevel single pass 7024 rod @ 160- 170A.
Posted : 23/04/2011 7:16 pm
wow! so busy with your welding wips na ha?
ako medyo pass muna ng konti, sobrang init ng panahon kaya spray painting and electronics stuff muna gagawin ko hehe
Posted : 23/04/2011 8:26 pm
Hehehhe spray painting .... tapos na welding mo kaya dyan ka na LOL Anong electronics yan WIP na yan?
I run out of paint so dry fit muna. At least it would be easier to pull the hose now.
Posted : 23/04/2011 9:01 pm
fafah jay,
hindi ka na newbie sa welding kaya dapat i post mo na sya as WIP mo para mahanap agad namin yang mga project mo para magaya hehehe 😀
sa kabayo ko gagawin, modified ko lang ulit yung dati kong ginawa na constant current circuit using LM317. dati kasi laging napupundi mga led's ko ngayon hindi na hehe
Posted : 23/04/2011 10:03 pm
fafah jay,
Hahahah sige pina pa graduate mo na ako.
Welding newbies. It's a good idea to install an integrated arc striking tester in your welder. It's better to strike an arc here first before going to the the work piece. I found that it is much easier to strike an arc in the workpiece when the rod is hot already.
Posted : 24/04/2011 1:27 am
Guys, I have a problem with my metal gate's lock.I can't find a picture but I'll just describe it.
Here in Pinas most metal gate has a sliding bolt lock with a handle right? Now that bolt slides into several short metal cylinders welded into the gate to guide the bolt's sliding motion.
One of the cylinders is welded and looks it had been hit hard and came down a few millimeters compared to the other cylinders.
Question is, cold I just hammer the thing upwards so it may align with the rest? My worry is that it might detach and I got no welder to place it back.
Thanks!
Posted : 24/04/2011 2:59 am
Can you grip it with a vise grip and try to bend align it instead of hammering?
Posted : 24/04/2011 5:20 am
Hmmm...never thought of that. Would that be a fool proof procedure or is there a chance that the thing might get broken and become loose?
Sorry to paranoid to have a broken gate and no welding supply nearby :confused:
Posted : 27/04/2011 11:27 pm
Page 66 / 79
