clayfigur
(@clayfigur)
Hmmm...never thought of that. Would that be a fool proof procedure or is there a chance that the thing might get broken and become loose?
Sorry to paranoid to have a broken gate and no welding supply nearby :confused:
Some times the Barrel bolt lock could just be mis-aligned due to frequent use.. but some times, like in my situation before.. one of the gates door is actually mis-aligned. I used a floor jack to gently lift the gates door back to its original alignment..
Perhaps, it could be the door that's mis-aligned..
Posted : 29/04/2011 8:01 pm
Hey bro saan ba place mo, pupuntahan kita at we weld ko yan para sa iyo. he he he he joke joke joke, just trying to cheer you up lang, don't be paranoid about your gate's lock.
The truth of the matter is if mag neighbor lang tayo e di spot welding lang siguro kailangan niyan at konting pukpok,baka ayos na yan. CHEERS
Posted : 29/04/2011 8:38 pm
uso pa ba pukpok during summer season? 😮
Posted : 29/04/2011 9:25 pm
HOY dito sa amin usong uso pa, kaya nga namamatay mga puno ng bayabas. 😮
HE HE HE HE HE, hi hi hi hi hi . :p :p :p
Posted : 29/04/2011 9:34 pm
hahahahaha 😀
Posted : 29/04/2011 9:39 pm
A MOSFET or IGBT Type DC welder will be the choice tool to service that gate if all goes South using brute method. Lightweight and can be plugged into household outlets. 🙂
Posted : 30/04/2011 2:08 am
i bought today a kilo of special nihonweld 6013 for 150p..never mind if its cheap or epxensive. i just wanted to try it...eyeballed, the diameter of the rod is about 3/32.
id like to know the properties of this special nihon...i hope the masters can chime in and enlighten me..i plan to weld a few angle bars, perhaps 3/16" thick. i dont know if this will suffice.
thanks..
btw..i was looking for the "consumables thread"...but lost my patience and posted my query here..sorry.
Posted : 30/04/2011 9:25 am
@V
If you have not read this yet then it would get you started.
http://www.millerwelds.com/pdf/guidelines_smaw.pdf
Posted : 30/04/2011 12:45 pm
Hey doc V, you need a welding table, I can design one for you free to fit your specifications and needs. You be the one na lang to assemble it and it will be great for you to practice welding while putting it up.
In other words its gonna be your first project and yet will be very useful to you in your succeeding projects.
Maybe a 24" X 24", or a 24" X 36" table top will suit your needs for the moment for practice welding and probably with an overall height of 34" or 36" so you will not be bending while welding, which gives you terrible back aches/pains/lumbago.
doc V, you may also check the thread by JayL re: EDUCATIONAL LINKS on welding, I have posted there some reading informations on proper stick welding and understanding your welders.
Posted : 30/04/2011 12:51 pm
@jay and rosy,
thanks braders...i saved the pdf files on the miller link. it sure will help me learn the basics of welding.
yeah my problem is the table..i dont know if i could build a table for this purpose this soon.
ironically, my doctor is planning now how to dissect me when here i am still planning to do this and that! hehe
Posted : 30/04/2011 1:14 pm
@jay and rosy,
Huh two years + ago I was in ICU for a supposedly heart attack. There I was with all the bells and whistles hooked up but thinking about an incoming shipment of tools to arrive the next day.
But I'm still alive. Worrying would have done me no good. 🙂
Way to go Doc V. Keep on welding.
Posted : 30/04/2011 3:42 pm
worries=problem=sickness
thinking=motivation=good health
thanks jay!
Posted : 30/04/2011 7:44 pm
posted below the nihonweld special 6013.
could not delete this first post which happened to be empty with links only.
Posted : 30/04/2011 8:21 pm
Posted : 30/04/2011 8:23 pm
@masters,
before i proceed with this welding thing...is my set up safe?
fused 60amp line with loomex (duplex) g14 wire to be hooked up with a 300A arc welder?
thanks!
i hate fires like all of you.
Posted : 30/04/2011 8:30 pm
Page 67 / 79
