Welding Table
14 Users
Re: Welding Table
Anyway alam mo na Hidalgo St..... pasok ... yun na yun ... pagdating sa unang kanan pasok uli then diretso na sa shop ko.
Aha!!! Alam ko na bahay mo Ninong Jay! Di kita mahanap last kwismas nung naghahanap ako ng aginaldo! 😀
Posted : 05/01/2012 1:13 am
Re: Welding Table
Ikaw pa ... Pasay Boy ka. Kabisado mo mga lugar dito.
Posted : 05/01/2012 2:09 am
Re: Welding Table
I have some scrap 1/8" checkered plates. Will make use of it to make a box.
Started cutting .....
plates now cut to size
dry fitting and preparing to tack weld
Posted : 05/01/2012 10:41 pm
Re: Welding Table
Tack welded ....
Full welded ....
Posted : 05/01/2012 10:44 pm
Re: Welding Table
It's late night now .... tomorrow I will grind the welds ...
this box is for holding used angle grinder consummables
I'll weld some hooks so I can hang it in the welding table ... it will be transferable and removable
Posted : 05/01/2012 10:47 pm
(@richard-gerard)
Re: Welding Table
@Sir Jayl
Your welding table is done in a very fine and professional approach, Yung mga gamit nyo po sa shop eh is of no question, puro high grade. If Sir Tim does the same approach in his woodworks eh kayo rin po sir and counterpart in metalworks.
Here in PHM, ang daming rin mga magagaling, iba iba po ang skill level and their approaches in accomplishing their projects, nakakabelieve. D 2 lang ako background mga braders appreciating and learning in the process sa different work skills and accomplishments.
Sir Jayl, i hope you have not forgotten, minsan naging suki mo ako sa IRWIN 4" Bench Vise, here in cagayan valley . Tnx the unit is vey much in tiptop shape.
Posted : 06/01/2012 5:59 am
Re: Welding Table
@Richard ...
Thank you very much for the kind words.
I try my best to equip and make the shop as efficient as it can be (as budget permits). Once done my thought is that projects will be easier to do and at a lower cost.
I'm glad you got one of those 4" vise. I have shipped a lot of those to provincial buyers. I believe it's not available anymore except for the last few pieces I still have.
Jay
Posted : 06/01/2012 11:28 am
Re: Welding Table
I have this 14 gauge sheet metal. My previous welding table top. I want two lower drawers for my new welding table and I could use this plate.
Sheet metal works is a different ball game. It needs a shear to cut the sheet and a press brake to bend.
I don't have the above so will make do with what I have on hand. Cutting plates using a CS is costly since the diablo blade is expensive.
I can cut the edges and hammer bend these to form a box. I can also slice up the plates and weld. Still undecided what to do. A press brake would have made things very easy. Will probably put this on the wish list. A lot of DIY plans available on the net.
Here I tested bending on two scrap sheets. Allowances have to be made for the bends.
If I slice and weld then I can have square edge joints. Probably more expensive to do but I need only 2 drawers. Shallow 2" high drawers.
I'm afraid the edges won't meet if I hammer bend as in the above ( of course I need to cut the edges first ).
Posted : 07/01/2012 8:15 pm
Re: Welding Table
Jay, wag kang maghammer sa edge ng top mo, mawawala ang flatness nyan.... ikaw rin :insomnia: :headache::thud:
:hysterical:
Posted : 07/01/2012 8:49 pm
Re: Welding Table
:hysterical:
Hindi .... meron plastic hammer ( Peddinghaus ...pang sheet metal talaga yan ) ... tignan mo uli yung pics. Pero slice ko na lang Timb then weld. Wala na kasi akong sheet pag na palpak ito. Test ko muna sa scrap next time yun bending.
Posted : 07/01/2012 8:53 pm
Re: Welding Table
Hindi .... meron plastic hammer ( Peddinghaus ...pang sheet metal talaga yan ) ... tignan yung pic. Pero slice ko na lang Timb then weld. Wala na kasi akong sheet pag na palpak ito. Test ko muna sa scrap next time yun bending.
basta wag mong pukpukan ha? :rofl01: :tounge2: :hysterical: :fartysmile1f:
Posted : 07/01/2012 9:00 pm
Re: Welding Table
This hammer is specifically designed for sheet metal use. It came with a Peddinghaus auto body works kit.
It will shape and bend sheet without basically over expanding the metal itself unlike a metal hammer will do.
It's the first time I tried it and it works better than the ball pein hammer in the pic when I did test bends on scrap.
Posted : 08/01/2012 12:43 am
Re: Welding Table
kaya nga brader, baka ma bend nya table top mo... :fart:
Posted : 08/01/2012 1:02 am
Re: Welding Table
AS per Master Moji's recommendation and Master Timber's advise not to hammer bend on the table top I sliced the sheets to build 2 identical sized drawers ....
Battery reload .... I wish I can purchase the tracks for these Metabo Circular saw .... not available in the US market. This CS is one serious tool. However the Diablo Steel Demon blade is more serious .... LOL.
As square as can be achieved for tight fit ups .... lessens warping.
I just need to cut the front and back stocks and these will be ready for welding ...
Drawer handle choice ... Bygel 128 Chrome
Will worry about mounting later ... the slides I have are long. Either source out new slides or think of another way to install these drawers to the table bottom.
Posted : 08/01/2012 11:10 pm
Re: Welding Table
aprub:chopper:
:biggrin: now go back to work:whipass:
Posted : 08/01/2012 11:30 pm
Page 12 / 19
