Welding Table
14 Users
Re: Welding Table
careful, baka ma-out of flat table mo brader.... hehehehe
Hehehehe palaban na table now ...
I forgot to mention that adjustments can be made by heating and rapid cooling using oxy ace flame. Used it on two high spots and it works.
When I get new refills I'll practice this technique on scraps to get a better hang of it.
Posted : 08/02/2012 10:28 pm
Re: Welding Table
I had anticipated this already when I did the dry fits ... I need to shim one caster as a result of warping .
Since the bolts are under ... the flex head ratchet is my tool of choice ....
Posted : 09/02/2012 5:51 pm
Re: Welding Table
The 110V supply line ... 12 Gauge
Posted : 29/02/2012 3:00 pm
Re: Welding Table
The convenience of a movable welding table.
Today I did a lot of grinding, evaluating abrasive discs. I can pull the table to the open air part of the garage. Grinding dust is not so much a problem for me now.
Posted : 07/03/2012 2:06 pm
Re: Welding Table
Bro JayL,
OT sandale, Jay I'm using now the grinding discs you gave me and results were very positive, cuts fast and grinds metal easily plus matagal maubos, The 14" cut off saw consummables, have not tried it yet but probably soon, one of this days. :cheerleader3: 😀
Posted : 07/03/2012 2:58 pm
Re: Welding Table
Bro ... notice the reinforcing fibers ... kamusta naman yung dulo ng mga discs? How about sparks and dust?
Dito sa akin napansin ko hindi masyadong ma vibrate.
What brand grinding discs do you usually use?
Thanks bro ... I hope you can post some pics too.
Posted : 07/03/2012 3:15 pm
Re: Welding Table
Fiber reinforced grinding disc
Posted : 07/03/2012 3:18 pm
Re: Welding Table
This generic thin slicer disc looks to be a cut above the Dewalt I tried before.
These are comparable to the German made PFX cutting discs I use now ( manufactured by Random House Inc. )
PFX type 27 slicer discs
http://www.randomproductsinc.com/pages/productcatalog/productcat.html
http://randomproductsinc.com/pages/productcatalog/catalog2010.pdf#d6
Generic slicer disc cuts
Generic slicer disc after several test cuts ... holding up well in my opinion
Posted : 07/03/2012 3:25 pm
Re: Welding Table
Posted : 07/03/2012 3:32 pm
Re: Welding Table
the pictures say a lot Jay, unfortunately I cannot understand (are the discs wearing fast?, We don't know how pfx perform so I can't relate, nor do I use dewaly discs)... hope you can explain a bit further what the pictures say...
Posted : 07/03/2012 11:48 pm
Re: Welding Table
@ Timb
So sorry I did not put additional explanations. I had meant the pictures more to be for viewing pleasure showing my welding table on use. I'll try to do some insertions later.
Posted : 08/03/2012 10:24 am
Re: Welding Table
Pwede din temporary mount for buffing machine
Posted : 08/03/2012 4:10 pm
Re: Welding Table
Let's see how the welding table can help while working on Wips.
Metal cutting time again.
I already wished I had the full size ( 4' x 8' ) 1/2" plate welding table ..... someday.
double cut ... saves time and makes sure the stocks are of the same lenght
my first rule when building shop tables .... these should all have the same height
Posted : 09/03/2012 11:24 am
Re: Welding Table
I'm going to make a filing folder wall shelf.
One of the secret for good miter cuts. Clamp the workpiece well so it does not move a bit at all.
Posted : 09/03/2012 7:07 pm
Re: Welding Table
I'm so happy I now have a welding table I can use to fab the small stuff I want to weld. Beats working on the ground.
Posted : 31/03/2012 9:12 pm
Page 18 / 19
