Another Stick Welder
8 Users
Re: Another Stick Welder
JayL, I also have this powercraft 200A stick welder like yours... works great... I bought it co'z I got tired carrying my uncle's 300A welder (really heavy)...
Hahahhah yeah I could imagine the weight of the 300A welder you have.
Thanks for posting and hope you post more of your work so we can learn from each other.
Posted : 30/01/2011 12:00 pm
(@melchor1025)
Tama po Sir Ossie new lng po ako sa group tama po kayo mas maganda po ang mig may kamahalan lng pero mas quality po ang weld kesa sa stick welding
Posted : 02/09/2017 8:44 pm
(@melchor1025)
Hi sir clayfigur san po made ang powerhouse pasensya napo newbie lng
Posted : 02/09/2017 8:46 pm
(@melchor1025)
Sana po ma çonfirm ang group requeat ko
Posted : 02/09/2017 8:48 pm
(@melchor1025)
Hi sir sabi sa forum mas ok din daw yung yamato igbt 200 or 300 amps or yung hotronic
Posted : 02/09/2017 8:50 pm
Yung HiTronic machine na piliin mo, well made and heavy duty, with 60% duty cycle, made by RILON Industries.
Posted : 03/09/2017 2:07 am
(@gumusut_amige)
if you're into heavy fab work. check the duty cycle. you are very safe on a WM with 60% duty cycle. highly recommending the weldtech brand. i have 10 units meant for training and they are still okay. only minor repair are done on some units (switch, LED display fault, etc) after more than 2 yrs
Posted : 11/09/2017 9:45 pm
(@melchor1025)
Thank you sir Gumusut for the info ,but it seems that sometimes in the store the welding unit has no display of the duty cycle ,in that case how do I know it just to make sure the one I buy is at least 60 duty cycle please advise.. thank you
Posted : 17/09/2017 5:43 am
