HiTronic Arc 300 Inverter
21 Users
(@tracykirilenko47)
You can use both the DCEN or DCEP for your electrode holder, which ever will suit you. But if you are going to weld
thick materials (surfaces), DCEP is the preferred one for deeper penetration. For thinner surfaces say less than 1/8"
down to 16 gauge plates, I suppose DCEN will have to be used to avoid burnt holes.
VRD is a safety device installed or fitted in all inverter welding machines. VRD stands for Voltage Reduction Device,
it protects and reduces the maximum unloaded open circuit voltage across the output terminals of the machine to a
safe voltage. 😉 :cool01:
ganun pala yun. nakakalito kasi yung sa manual. kaya pala butas yung mga weld namin ng bro ko. by the way, im not a trainer/assessor ng smaw or any kind of welding that's why im asking. papasok pa lang ako ng traning and just preparing before training para makapag practice na at advance learning na rin. concrete works kasi ako trained at sa small engine. thanks sa tulong.
Posted : 31/08/2016 1:11 am
How thick or thin is your weld material, baka masyadong malakas ang amperage mo. Also what rod electrodes
are you using, is it the 1/8" rod or the 3/32" rod ?
Posted : 31/08/2016 1:48 am
Bro, reviewing the front and back of the welder, the only switch that I see is the one in front which is the
ON and OFF switch. The indicator light is for the warning lamp in case you have exceeded the duty cycle or have over used the machine which I doubt it will not since you are just practicing with it yet. Mine haven't reach that point yet after all these years of use.
Posted : 31/08/2016 11:18 am
(@tracykirilenko47)
Square tube. E6013 1/8" rod
Posted : 31/08/2016 3:20 pm
jantech
(@jantech)
Try using yung nihonweld 6013 special mas ok sa manipis na steel un. Btw ano thickness ng square tubing mo?
Posted : 31/08/2016 8:12 pm
(@tracykirilenko47)
My hitronic arc 300 amp welder. Ngayon ko lang nakunan ng pic.
Posted : 13/09/2016 6:32 pm
(@tracykirilenko47)
My Hitronic Arc 300amps. Ngayon ko lang nakunan ng pics.
Posted : 13/09/2016 8:10 pm
(@tracykirilenko47)
my hitronic arc 300amps welder. ngayon ko lang nakunan ng pic.
At the back, the voltage reduction device (vrd) switch
isama ko na rin ang mga tools ko na matagal ko ng nabili pero ngayon ko pa lang gagamitin
Posted : 13/09/2016 11:33 pm
(@tracykirilenko47)
Posted : 13/09/2016 11:38 pm
(@tracykirilenko47)
continuation
Posted : 13/09/2016 11:53 pm
Bro tracyk,
Pics of your HiTronic welder did not register on your post.
By the way the Milwaukee brand is a good brand, I know it will last you long. I too also have the angle grinder
and its a joy using it, its brute and smooth to use.
Congrats !
Posted : 14/09/2016 2:15 pm
(@isfunkee)
sir ok lang ba kahit hindi nakakabit yung ground? yung sa akin kasi Hitronic 200T Arc 3 blue, brown and yellow/green yung wire nya?
Posted : 15/11/2016 9:11 am
Bro isfunkee,
OK lang, when I got my unit the ground wire was already factory tied down sa main cord so I guess there is no need to attach it to my plug. Look at the pics posted above and if you will look closely behind the unit there is no connecting prong for any ground connection. Now I just don't know with other units for 200 amps. Baka yung yellow green wire ang ground wire mo. Hope this helps.
Posted : 15/11/2016 2:42 pm
(@jamrocks)
Boss tanong ko lang anong pangalan nang mask mo para sa ilong at saka saan tayo makaka bili nyan. plano ko rin sanang bumili nang ganyang mask.
Posted : 10/12/2016 8:51 am
Bro jamrocks, its a 3M Half face mask respirator. Better get in touch with bro joey81, send him a private message, he might still have a unit or two. Locally there is a store somewhere in Avenida St. selling this 3M respirators etc. Sorry but I just forgot the name of the store. Mine was bought from amazon.com.
Posted : 10/12/2016 2:00 pm
Page 8 / 9
