Hitronic Mig 250F : Unboxing, Review, and Feedback
6 Users
(@avmanansala)
Wood and Steel work, Party later.
Posted : 10/08/2016 2:11 pm
jantech
(@jantech)
LOL 😀 mukhang wala ng party later mahirap na tanggalin mga gamit dito. Inuman later na lang :cheers:
Posted : 10/08/2016 3:40 pm
jantech
(@jantech)
Additional buy... Anti Spatter gel, 3pcs nozzle, and 20pcs 0.8mm contact tip. About 2400 pesos total.
Posted : 12/08/2016 1:11 am
Nice cart brader..threaded ba yung nozzle? May replacement liner din kaya sila or mig gun assembly na fit sa lincoln?
Posted : 12/08/2016 1:41 am
wow! 850.. 1,300 kuha ko dito sa Malolos. kay Balangcas trading
Yan din supplier ko ah! 1,200 naman sakin..check mo nga brader kung 2000 psi ang full nya..last 2 delivery nila sakin is 1,800 psi na lang..
Posted : 12/08/2016 1:48 am
(@avmanansala)
wow! saan ka nakabili anti spotter Gel?
Posted : 12/08/2016 2:27 pm
jantech
(@jantech)
Yung nozzle hindi threaded isasalpak lang tapos parang may grip un. Hindi ako sure kung may liner or mag fit sa Lincoln pero sa tingin ko lang meron. Kasi nung bumili ko hindi naman tinatanong kung ano ung brand 🙂
Posted : 12/08/2016 3:56 pm
jantech
(@jantech)
Nakalimutan ko ung name nung store pero sa t Alonzo ko to nabili siguro mga 3 stores sa left ng evervbest achievers. Mas mura din ung contact tip dun kaya dun na rin ako bumili ng contact tip.
Posted : 12/08/2016 3:59 pm
(@avmanansala)
dami mo naman binili contact tip. nakaubos na ako 5kg wire and 1 cylinder never pa ako nagpalit ng contact tip. pero siguro pag thick gauge weweldingin baka mabilis masira ang contact tip
Posted : 12/08/2016 7:46 pm
jantech
(@jantech)
Lol sayang kasi yung 100 peso off
Posted : 12/08/2016 10:45 pm
(@avmanansala)
try mo pala 0.6mm na wire sa mga thinner gauge metal like square tubing
Posted : 13/08/2016 1:49 pm
jantech
(@jantech)
Interesting... Will definitely try that out
Posted : 14/08/2016 10:29 pm
jantech
(@jantech)
Ok after the dry run totohanan na testing naman kahit bumabagyo welding pa rin! Using 0.8mm mig wire on a 1.5mm square tubing... Voltage set to 17V (knob #1), wire speed set to 5.5mpm (knob 3), gas flow set to 15 liters per minute.
Weld penetration is good, the hole there can easily be covered. Mig puddle is good and stable.
Quite happy with the result. After this testing I said to myself "tama na testing totoong project na!".
So I started my first mig project... A steel storage rack...
Posted : 15/08/2016 2:45 pm
jantech
(@jantech)
Amazing how effective the nihonweld anti-spatter is. This is a MUST have, do not start mig welding without it.
Posted : 15/08/2016 2:46 pm
Maybe you should continue practicing with Mig applications, testing different settings and finding that sweet frying bacon sound.
Also try shortening your wire stick out to 1" or 3/4". 🙂
Posted : 15/08/2016 6:38 pm
Page 3 / 4
