Lincoln ProMig 180
11 Users
Re: Lincoln ProMig 180
Thanks bro..
Posted : 15/03/2014 8:44 am
coolmaxheric
(@coolmaxheric)
Digital and Inverter sya..
Iba pala yung pinost ko sir, hehe..
3-in-1 pala yun, Nagulat kasi ako parang parehas modelo.. 🙂
Coming to stores near you daw :soon:
Posted : 15/03/2014 11:06 am
Uy Wow ! Kelan kaya dadating sa stores near us ??
Sige nga ng makilatis yang welder na yan, may come out very promising ! ;):p
Posted : 15/03/2014 12:56 pm
Hehe..ayun oh..kulamin na yan!
Bro heric post mo nga yung actuall unit..baka mahalina ang isang mama jan..har har
Posted : 15/03/2014 1:24 pm
(@miked)
eto ang ayaw ko sa phm. pinapahaba ang wish list ko. hehe
ampogi ng bago mong laruan brader bugel...atsaka yung weld beads mo. baka magiipon na ng alikabok nyan si yamato dc. gaya nung nangyari ke yamato ac. hehe
Posted : 18/03/2014 3:09 pm
Thanks bro miked..parehas silang naalikabokan lang..walang wip eh..
Posted : 18/03/2014 6:52 pm
deanorbs
(@deanorbs)
Just saw this last month!
Lincoln din pero Powercraft..
Same model pero may nakalagay na PowerCraft nga lang..
Pa-PM din price sir bugel, hehe
Nice Score Sir Bugel! :slurp:
sir, saan nyo po nakita itong 3-in-1 na Lincoln? magkano po ang price? thanks..
Posted : 10/04/2014 6:16 am
(@dtsinelas)
3 in 1 na lincoln iskor din ako nyan...magkano kaya kaylangan ipunin hahaha sarap
Posted : 20/10/2014 9:49 pm
(@dtsinelas)
mga sir pareho lang bang gas ang gamit sa tig at cut?? para sa 3in1 w.machine
Posted : 20/10/2014 9:55 pm
Bro, I don't have a Tig machine yet but based from research, for Tig welding, you will use pure
argon as your shielding gas. As for cutting, if you are referring to oxy-ace cutting, you use a
tank of oxygen and a tank of Co2 or oxygen and an LPG.
:bokmal: 😉
Posted : 21/10/2014 12:08 pm
(@thugstools_413)
if you do have a flux core filler wire your welding process is Fcaw and you only need a Co2 gas for it....and if ever you use the er70s it is solid wire and your welding process is MIG and you need a mixture gas of Argon/co2...hope am right!
Posted : 10/06/2016 1:46 am
dual shield kung fluxcore plus shielding gas..and yes FCAW din ang process..may lincoln innershield wire ako di na kailangan ng cO2 to use it,flux inside the wire itself ang mag sisilbing shield against contaminant.parang stick welding lang ang pag kakaiba nga lang nakabalot sa stick electrode ang flux nya..
Posted : 15/06/2016 2:07 am
(@cmorales)
- How much is that?
I really need this because I can bring it somewhere. 🙂
Posted : 16/06/2016 7:49 am
(@ricofrederick)
boss ,,, paano ba ang connections mo, diba ang welder na yan has three prongs, 2x110 volts and a neautral.... pls help me.. i have 2 mig welders lincoln 180 and hobart 175... all 220 volts. Likewise i recently bought the new lincoln multi proces inverter type ( tig, mig and smaw) also 220 v. I just want to make sure i dnt mess up with the connections. Nandito pa sa toronro yong mga unit, balak kong dalhin sa pinas. What do accessesories do i need to keep this machines running? thanks for your help
Posted : 16/06/2016 11:48 am
