YAMATO 200amp DC Inverter
35 Users
Re: YAMATO 200amp DC Inverter
Get a Jackson brand of electrode holder, available now in most hardware stores in Marikina or Antipolo or you can pass by Toolec sa may Eastwood City. 😉
Posted : 06/03/2014 1:03 pm
Thanks. Will look for the Jackson holder.
On the cable, I assume I can just say welding cable and the'd know what it is, right?
Posted : 08/03/2014 8:11 am
I am trying to recall the time we did the group buy of the Yamato, when you got your unit, hinde ka ba kumuha ng Jackson electrode holder from Ms Mimi coz I think we all did as an upgrade for the lousy holder that goes with the unit.
Anyway Ding it will really be useless whether the new rod holder you'll buy is cheap or expensive if you just habitually drop your electrode holder after each weld applications, 😮 talagang masisira or mababasag agad yan !
With regards to the cable, yup just tell them welding cables but also be specific of the length you'll
need, some stores sells per foot, others per meter. 😉
Posted : 08/03/2014 11:03 am
You're absolutely right, Rosy. I should be more careful with my welding gear. I noticed that the two halves don't align properly anymore.
What makes worse for me is, unlike woodworking where I work on a workbench, when I do metalwork, I work on the rough garage floor. I never got the caring habit of laying down tools gently because I'm usually barumbado sa workbench. I once tried putting some scrap particle board to soften my surface. Muntik na magkasunog. 😀
Posted : 08/03/2014 12:16 pm
Pwede ka rin mag fab ng stinger holder sir ding..para pag katapos mung mag hinang may lalagyan ka na ng electrode holder mo..safe pa..
Original toyota car stereo model 851-yza81
Posted : 08/03/2014 12:33 pm
Hmmm...tomorrow...Thanks!
Posted : 08/03/2014 6:02 pm
(@leahcim)
have a gud day po sting lahat mga bros..newbie lng po aq..ask lng po sna aq about sa yamato inverter welding machine..naghahanap po kc aq ng legitimate seller at ung nagsi ship dto sa prov..ideal ko kc is 300A,may nkta po aq na mga ads na may 300A in d price of 7.5k at meron ding 300A din na ang price is 13k at ang nkkta kong pgkakaiba nila eh ung digital screen monitor.bukod po doon anu pb ang pgkakaiba nila mga sir kung bkit mas mahal po ung isa.cnu po pwd nyo recommend na seller na pwd shipping here in prov..kung may mas mgnda pa kau recommend na seller na mas mura ang benta very appreciated..need ko kc for my agri machinery works pra din sa maliit na babuyan ko pra s kulungan nila..tnx a lot po..gbu
Posted : 16/10/2015 10:35 am
(@leahcim)
kait 200A po kung tlgangng subok na nyo eh pwd na din mga sir..tnx
Posted : 16/10/2015 11:47 am
@ leahcim,
Bro, google mo ang Goldpeak Tools and Hardware for your welding needs. Look for Heric (coolmaxheric), also a member of this forum.
If out of stock ang DC Yamato, you can settle for HiTronic 250 amp DC Inverter or the Powerhouse 300 amp DC Inverter.
AC stick welders are much much cheaper than the DC inverter weld machines. But you see DC Inverter machines have a soft start with
less spatters and saves a lot on electric consumption plus it can be plugged in an ordinary household outlet. Also has a window readouts
to see actual the precise ampere settings.
OT : Kindly introduce yourself to the forum, we have a Member Introductions at the lower portion of the PHM index page.
We'd like to know you better as a new member of this forum.
Thanks,
Posted : 16/10/2015 3:54 pm
(@leahcim)
tnx sir rosy and gbu,,,
Posted : 16/10/2015 5:15 pm
(@astig-panday)
saan po makakabili nito?
Posted : 06/01/2016 12:59 pm
Simply read the posted replies, sources of this welder are there with their respective contact nos. and addresses.
By the way please do introduce your self, PHM has a MEMBER INTRODUCTIONS just down below the index page,
its under the Gazebo Forum.
Thank you.
Posted : 08/01/2016 1:21 am
Page 13 / 13
