Bugel's mig projects
6 Users
Re: Bugel's mig projects
Salamat miked..
Kung sa stick welding mejo tricky pag deposit ng beads sa fillet weld..kailangan mejo mabagal ang lakad ng rod ng sa gayon kumagat sa dalawang gilid ang hinang para maiwasan ang worm hole..ako kasi Ina adjust ko ng hotter than normal settings ang machine para maganda ang wet out ng puddle.mas lusaw kasi ang bakal mas nakikita ko sa adh kung ano at paano ang gagawin ko habang nag hihinang..sa ganyang paraan mas nailalatag ko ng maganda at solid ang beads..mapa mig man ito or stick welding..
Yeah, what bro bugel said is absolutely true, for me doing stick welding has done this lately increasing the amperage a bit more and it works great specially for fillet welds but be very careful if its the thin walled surface, increasing the amperage may easily produce burn holes on the surface, but with thicker wall surface, it does works fine.
I suppose once you've got the various techniques going doing stick welding, it will be much easier to learn and apply those weld beads with the mig process.
Anyway, nice weld puddles on those projects bro !! 😉
Posted : 24/11/2014 10:40 pm
galing nman bugel..expert welder na talaga..manang mana ka na kay rosy ah.
Posted : 25/11/2014 10:14 pm
Inay ko po! sorry to disappoint you bro Armand pero wala ako sa kalingkingan ni bugel. Siya ang expert at master welder dito who can accept welding projects from clients in their area, kung baga ay commercial grade na ang kalidad ni bugel sa larangan ng welding. 😎
HEHEHE, for me its just for DIY purposes lang muna. Someday perhaps when I'm about to put up my own metal shop and start accepting welding projects or maybe creating some metal sculptures.
CHEERS and thanks bro ! 😉 😀
Posted : 26/11/2014 11:46 am
(@miked)
confirm ko lang brader kung ano settings ng welding machine (inverter) sa sinabi mo na hotter than normal. ito ba ay DCEN (DC electrode negative) kung saan mas mainit ang work kesa sa welding rod.
kung DCEP (electrode positive) kasi ay mas mainit ang welding rod kesa work.
pasensya na mga sir. OT na.
Posted : 26/11/2014 11:59 am
ang tindi ng hagod mo sir bugel, talagang di ko mapalampas na masabi ang paghanga ko. sineryoso ko ang welding course ko sa tesda pero di ko nagawa ang galing mo, kailangan ko pa ng maraming maraming practice. keep up the good work bro.
Salamat bro Elpie..
Tama ka practice at pasensya Lang ang katapat nyan..ang importante sa welding kailangan mapag aralan mo I read ang characteristic ng weld puddle,nung una kasi ako nag aaral puro liwanag Lang ang nakikita ko sa helmet ko,ang trick Lang pala I focus mo Lang ang mata mo sa liwanag hangang sa makita mo ang nalulusaw na welding rod at base material..ngayon pag nakikita mo na ng klaro kung ano nangyayari sa welding rod habang nag hihinang ka madali na Lang I manipula ang pag dedeposito ng weld beads..
Posted : 26/11/2014 7:17 pm
Salamat sir armand/sir rosy..
Sir rosy..sa stick welding thread mo ako namulot ng teknik kung paano gumamit ng welding machine at kung paano mag latag ng magandang beads..kaya agree ako sa comment ni sir armand na nag mana Lang ako sayo tatay rosy..hehe..
Dahil sa mga project mo at ng ibang member ng PHM like sir jay,ossie,ryobi atbp. Na inspire ako at na motivate na mag aral sa larangan ng welding.
Posted : 26/11/2014 7:46 pm
Bro miked..
DCEN brader mas maganda nakikita kong result sa 6013..
Ang ibig ko Lang sabihin sa hotter than normal,sa amperage setting yun..
For example..kung ang desired amps settings for certain material is 100 amps,I add extra 10 to 20 amps..so it is more hotter than usuall amp settings,sa ganyang paraan kasi di concave ang result ng weld beads..
Yan kasi ang ginagawa ko para mag penetrate sa root at wall pag may hinihinang akong t-joint or fillet weld..
Posted : 26/11/2014 8:30 pm
(@janmike)
Can't help but to admire those welds. Nicely done sir bugel! Cant help to notice your mig machine which i believe is a lincoln 180? I recently repaired one of those machines, rebuilding much of its internals. Took me quite sometime to design a replacement circuit for it as the parts are not available locally. When i got it to work again it was a thing of beauty. Luckily i took some pics..
Posted : 29/11/2014 9:58 pm
Thanks brader..yes lincoln 180 it is,glad to know na may pag dadalhan ako ng unit ko pag nasira,pero wag naman sana he he he..fit kaya ang parts ng ozito or cigweld sa lincoln?like tip,nozzle or liner?
Posted : 15/12/2014 8:16 pm
Hitch receiver for my welding table vise..
2x2x1/4 angle bar
Weld together..
Posted : 15/12/2014 8:20 pm
Full weld lahat para matibay..
Posted : 15/12/2014 8:21 pm
Lagyan natin ng kurba..
Hinang ulit!
Posted : 15/12/2014 8:22 pm
Heto na ang pyesa..
Bolt in na..
Posted : 15/12/2014 8:23 pm
Mabilis magtangal kabit pag kailangan ko gamitin ang buong lapad ng table ko..
Baka magamit ko din ang ganitong orientation ng gato..
Posted : 15/12/2014 8:25 pm
Ayan may primer na..
Posted : 15/12/2014 8:26 pm
Page 2 / 5
