MIG Welding Newbie
25 Users
Re: MIG Welding Newbie
Jay, If you could get Bosch metal Progressor blades I think you can cut a slot there as the blades could handle up to 3/8 thick metal sheets.
PROGRESSOR®
Ideal for thick and thin metal
Progressive tooth spacing for fast cuts, long life in metal,
Sheet metal 5/64" to 3/8".
Non-ferrous metal 5/64" to 3/4".
Stainless steel 1/16" to 1/8".
Fiberglass 3/64" to 3/4".
MATERIAL: HSS
Posted : 28/07/2011 4:15 pm
What do you think? Shall I slot all 5 holes end to end? By the way the holes are 1/2" diameter.
I can oxy ace cut it but too lazy to build a straight torch cutting jig only for this.
Trial ...
Posted : 28/07/2011 7:04 pm
Here ...in the end the Oxy / Acetylene slot cutting was the best choice available for me
Posted : 29/07/2011 3:59 pm
and now for some elbow grease ......
Loading up the files with chalk helps when filling metal ... less clogs. Mexican made Bellota files are good and available at Panda with reasonable prices
I can now slide the clamp ... not much but better coverage than before. I chose not to weaken the plate by having longer slots. My reasoning is that once this plate goes into service welding heat can easily warp it so it's better to reserve surface strength.
Posted : 29/07/2011 6:05 pm
I cut the head of a 5/8" fine thread bolt
drilled a hole in the center of the plate
top side with the bolt in place
bottom side
ready for welding now
Posted : 29/07/2011 11:51 pm
Top side welded ....
I can do a second pass , lower the amps and tie the edges but I'll just leave this as it is now.
ground the bottom tack welds and prepare for full welding the bolt to the plate
This one needs to be clamped well as plate warping will be expected specially I'm welding at 7.5 setting with a wire speed of 100. The thickest the Miller 180 can do in a single pass 5/16". Spray transfer. The high amps melts the wire even before it touches the metal again, becomes small globs and is sprayed into the metals to be joined via the hot surrounding shielding gas.
Posted : 29/07/2011 11:55 pm
Owyn suggested that I should beef up these welds. I think I got carried away by the sound of the mig welder and did a lot more passes than necessary. At this point I still don't weave weld ... only straight push or pull. Anyway I'll just grind the excess welds here.
The clamps were also blocking my gun path that I could not make continuous passes. I should have inverted the C Clamp positions so I can get better gun access to the metals to be joined. Newbie error.
Here take a look again. The c clamp handles should have been pointing downwards. LOL Well another lesson. Always review your overall gun access path before starting a weld.
A long welding rod will not pose as much of a problem given the same scenario when using a stick welder.
Posted : 30/07/2011 12:41 am
Welded the nut. Dang I forgot to clean the residue oil on the shock absorber tube with lacquer thinner again. Too much smoke from burning oil.
The welding positioner prototype looks like it will work. Hmmm a tilting mechanism for back front movement will be useful. Will do one when I make the positioner for the welding table I'm planning to build. However I will use longer 1 1/2" and 2" GI pipes.
Posted : 30/07/2011 1:56 am
Lots of errors but I'm getting to know the mig welder's adjustments better now ...
up or down / side to side adjustments
The good thing is that the ground clamp can be connected to the positioner itself. Will review the contact points and ground path later.
The mini table top can also rotate
I can either mount this jig on this mini welding table or on my folding table ... I just need to make some brackets so I can weld the base tube to a table for stability.
Posted : 30/07/2011 1:58 am
Great project you got there JayL, very nice and will be very very useful welding positioner. great for welding projects to be clamped on top, can be rotated 360 degrees, can also be raised up and down to a desired height and probably tilted from 0 to 90 degrees flat. 😀
I'll be making one too in the near future after I finish my welding table, I purchased the 36" X 1/2" round table top and the 24" X 24" X 1/2" thick square together with the 3 panels of table tops that I'll be using for the welding table. Maybe I'll be installing the 24" X 24" on one end or corner of the welding table so that I will have also a rotating table top nearby. The 36" round table top maybe I'll make another welding table and improvise a way so that it can be tilted and rotated too, well lots of welding projects here too. 🙂 :showoff: :p
Have a nice and productive day JayL.
Posted : 30/07/2011 9:05 am
That's good thickness you got there for a welding table top. I'm also with the idea that a good welding table should shave at least 3/8" thick plate but 1/2" is better if it will not be moved a lot.
Posted : 30/07/2011 9:18 am
@Rosy
Bro if you will be building a welding positioner for your table you might want to check this link below.
A manual welding positioner for the rest of us poor boys
The idea of my positioner came from this generous welder who shared his jig. All credit goes to him.
Posted : 30/07/2011 1:06 pm
Here is another welding positioner.
Posted : 30/07/2011 1:07 pm
(@ricky)
Sir JayL very nice and detailed WIP, very inspiring indeed.
Posted : 30/07/2011 2:02 pm
Thanks Ricky. I'll coat it with paint it when it's done.
Posted : 30/07/2011 3:18 pm
Page 12 / 32
