MIG Welding Newbie
25 Users
Re: MIG Welding Newbie
At last I can now position the MIG Welder wherever it suits me well in the garage.
Here is a very very long overdue task from my Welding Newbie days. Our rusting wicket door repairs.
This Metabo cordless angle grinder is a sleek tool. Here I cut 24 inches of 1/8" thick flat bar in order to make it flush. First run for the grinder and it was doing the task as if it was an electric angle grinder. Finished the job and still with battery juice left.
Thin sheet patching ......
Posted : 24/11/2011 11:28 pm
Sheet from an old computer case cover
Too lazy to reload the welder with sheet metal wire ( 0.023" ) .... just used the loaded 0.035" wire.
Posted : 24/11/2011 11:33 pm
Next time I will order Lincoln Easy Grind MIg Wires for sheet metal. The regular wire I use is just too tough to grind down easily.
Posted : 24/11/2011 11:35 pm
joooeykikoy
(@joooeykikoy)
...your speedglas jayl is a real beauty! sweet helmet you got there 🙂
Posted : 25/11/2011 2:54 am
ayos!!! iba talaga pag may bagong tools, madaming nagagawa... syempre dapat makita ni SMBO na nagagamit yung mga tools hehehe
go go go!!
Posted : 25/11/2011 5:35 am
Thanks bro. I really did not know what I was missing in welding till I got chance to use one of these 3M helmet.
Posted : 25/11/2011 11:32 am
go go go!!
Oz ..... siyempre pakitang gilas konti LOL.
Hindi lang talaga ma maximize mabuti kasi bawal sa akin mapagod ng sobra. Usually max WIP time ko 4 hours lang.
Posted : 25/11/2011 11:37 am
Bro JayL,
Pre for your health benefit, you have to and I urge you to pls Q U I T S M O K I N G !!!! Yan ang nag papahina sa iyo, sa resistensya mo.
Bro I think I an older than you are but I can still work more than 12 hours a day, sumasakit lang paa ko pag laging nakatayo specially when metal working or trimming my lawn/gardening.
Don't forget too to take lots of vitamins and food supplements, concern lang sa health mo pre, hope its OK? Or maybe you should start going to the GYM and start exercising and stretching your muscles and probably do some cardiovascular exercises, very good for the heart and lungs.
Posted : 25/11/2011 12:38 pm
Bro JayL,
Yes bro. Thank you very much for the reminder on smoking. It is my number one enemy.
A lot of my friends suggested also that I try one of this electronic cigarettes. Most of them have switched to it now.
Posted : 25/11/2011 1:20 pm
Bro JayL,
oo nga naman Jay, masama usok... nakakahina yan... bawasan mo na or tigil ka na smoke :naughty2::naughty2::smoke:
Posted : 25/11/2011 1:56 pm
Hehehhe ... subukan natin yung electronic cigarettes naman hahahhahhaha
Posted : 25/11/2011 5:27 pm
Today I went to check for double locking caster 5" size. I went home empty handed. It seems like this type of casters are only single locking. Means only the wheel rotation lock. I need it to lock the swivel movement at the same time.
I wanted to put 4 double locking casters but if not available then I will have to settle for 2 non movable casters ( back ) and 2 single locking casters ( front ). I'm not sure how much mobility will be hampered since it is a very heavy welding table ( around 150-200 kg w/o load ).
Bro Rosy ... please comment if possible.
Please let me know if you guys find double locking casters.
None the less I found some NOS long clamps for the table. Supplies for this long jaws vise grip style locking pliers are drying up.
19" Lock Jaw and 24" Petersen Vise Grip
Posted : 25/11/2011 5:41 pm
Those electronic cigarettes are just a fraction of your tool's price guys. There's no harm in trying, all healthy and thrifty.
Posted : 25/11/2011 5:43 pm
nyahahaha oo nga naman, itigil nyo ng DALAWA yan hehehe 😀
Posted : 26/11/2011 11:43 am
patchpower
(@patchpower)
Next time I will order [COLOR="Red"]Lincoln Easy Grind MIg Wires for sheet metal. The regular wire I use is just too tough to grind down easily.
sir JayL ask ko alng po ano po AWS # nitong Lincoln Easy Grind MIg Wires? TIA
PAX is the leading manufacturer and exporter of PATCH/Seal String in Taiwan and our quality to be equal to the productions made in U.S.A, Germany and Japan.
Posted : 03/12/2011 2:15 pm
Page 29 / 32
