MIG Welding Newbie
25 Users
Re: MIG Welding Newbie
AAHHHAAAAA, So this is what was keeping you so busy this past few days bro !!, that's why pala medyo nag disappearing act ka muna ha. That's one cool project bro !!!!!
Posted : 19/04/2012 9:39 pm
puede nang mag-picnic dyaan sa place mo jayL....:chef:
Posted : 19/04/2012 11:48 pm
Hehhehhe pwede ng pang shabu shabu ..... 🙂
Posted : 20/04/2012 10:34 am
Rolling Cooker Stove WIP
Day 2 .... wala pang flooring 🙁
Posted : 20/04/2012 5:55 pm
Small stuff bending is a breeze now since I found these Oxygen Bottles at HMR. Even tool steel is no match when heated by oxy fuel. Bends like alambre.
For hanging the WOK.
Posted : 20/04/2012 8:00 pm
Run out of steel so I waited for the delivery which came today ....
had some time to start the flooring for the stove rolling cart ....
cut some spacers on the TS
to be continued
10mm square bars
Posted : 21/04/2012 8:13 pm
Posted : 22/04/2012 7:34 pm
To be continued .....
Posted : 22/04/2012 7:35 pm
I managed to finish the welding today. I have kept it as simple as it could be. The rolling stove should be very easy to clean with hose water as it will see a lot of action cooking food for our Mercato weekends food stall.
I have spent around 1,500 pesos on the metals used.
If I have chance I'll spray paint it tomorrow.
If ever I get to build one again I will use stainless steel as I'm now more confident doing this kind of WIPs.
Posted : 24/04/2012 8:23 pm
My 3M 9002X Speedglas Lens is back from warranty claim in the US. Kudos to 3M for sending me a new replacement.
Posted : 03/05/2012 8:44 pm
Aluminum Mig Wire
Posted : 04/05/2012 2:33 pm
My welding table gets a new connection to the welders...
These ground clamps can be connected to the mig or stick welder depending on which one is best to use ...
( i.e for sheet metal works a magnetic clamp is better)
Posted : 06/05/2012 4:21 am
Easy way to weld squares .... tack and weld using magnets
Posted : 10/06/2012 9:36 pm
I love using stop blocks when cutting with chop saws no matter how crude the setup is ...... makes repetitive cuts quick and easy.
It's important to place a spacer which can be removed so the saw blade will not pinch the metal at the final cut.
Measure once cut many .....
Posted : 12/06/2012 7:44 pm
Stop blocks for chop saws, drill press etc.... I wish I had better setups for it.
Posted : 13/06/2012 12:11 pm
Page 31 / 32
