MIG Welding Newbie
25 Users
Re: MIG Welding Newbie
Ninong, is that an eye expansion bolt that you fastened into the wall? Where and how much does each one cost? What are the dimensions as well? Thanks!
Yes... it's only a small one because it's just temporary for me. 10mm / China 2 pcs 65 pesos - expansion bolt with eyelets.
Hardware store near Taurus Auto Supply in Arnaiz St.
Do you know what they call that cable/chain puller?
Posted : 08/07/2011 2:17 am
WIP na kaagad yan hehehe hangganda!!!
Posted : 08/07/2011 11:05 am
Thanks for the info Ninong. Btw, the part that you're asking is called a turnbuckle
http://en.wikipedia.org/wiki/Turnbuckle
I see this mainly used in metal swing gates, large metal mast support, boxing rings, etc.
Posted : 08/07/2011 12:21 pm
Thanks Jarod.
You are indeed the link master here. 🙂
Posted : 08/07/2011 1:36 pm
Thanks Ossie. Ikaw puro True Blue mga nasasagupa mo na diyan ano .... hehehhehehe
Posted : 08/07/2011 1:42 pm
Practice time again. Need to reclaim more floor space thus a bench grinder wall stand.
Improvised stop block. It's so difficult to work on the floor ... 🙁
Posted : 09/07/2011 6:40 pm
Dry fit
Mas maganda sana yung square bending technique ni Ryo kaya lang ang lutong netong angle bars na ito so puro putol na lang.
Pasensiya na mga bros ... mas madami kasi online time , coffee and yosi time kesa sa Wip kaya medyo mabagal matapos. 🙂
Posted : 09/07/2011 6:42 pm
Mig welding 101 : getting to know the process and the machine.
I specifically chose aserado angle bars for this as I have not had very good success welding this using my 200A Stick welder.
The current setup - no cart and welding table as yet.
Proceeded to weld the angle bars. Still letting the machine auto setup adjust weld parameters like wire speed and volatge. All it needs from me is the thickness of the metal I'm welding. This is the Idiot proof way but manual is still the best option which I will use once I learn more about the welder.
So far so good no burn through ...
I specifically did edge welding to see how the welder will handle it. My stick welder will make a mess out of this.
Posted : 10/07/2011 6:37 pm
I then proceeded to grind the welds to see how the metal pieces were joined.
the penetration side ... ( tack welds prior to full welds also shown )
So far better than my 200A AC welder. I also note the ease with which the welds were done on the side of the operator.
Notice the operator error on the last two pics. I did not aim well to make sure the welds were centered on the joints thus applying more heat on one side.
Posted : 10/07/2011 6:41 pm
very very nice Jay, ganda ng welds. I'm sure mas madali rin linisin than the previous. Congrats. seems like you're gonna love this machine...
Posted : 10/07/2011 6:50 pm
Thanks Timb. Yes cleanup was one major reason I chose gas welding. No slag and so far minimal spatter too.
Posted : 10/07/2011 6:53 pm
(@ricky)
Hi-tech ng welding machine nyo sir. Thank you sa suggestion re rilion brand welding machine. Will get it Tom, pwede na muna yung160amps since wala pa official projects, tamed Lang ako mang Hiram na nun bulky unit ng office lol.
Posted : 10/07/2011 10:37 pm
parang walang duksungan, hindi halata...
getting better and better in no time.
:drive1:
:congratualtions:
Posted : 10/07/2011 11:13 pm
Thanks for your encouragements bros.
Here is the carbide burr in action grinding spot welds so I can place the sheet metal flooring flush to the angle bars.
Very fast metal cutting tool. However it needs full protetcive clothing and safety gears. Look a the sharp fine metal shavings.
Posted : 10/07/2011 11:21 pm
@jay
parang ayaw ko ng mag post ng welding spot grabe ang linis tsk tsk :superhero2:
Posted : 11/07/2011 3:39 am
Page 9 / 32
